| Jimny transfer jumping out of gear? http://auszookers.com/forum/viewtopic.php?f=5&t=36058 |
| Author: | bigdogdazza [ Mon Oct 01, 2012 6:35 am ] |
| Post subject: | Jimny transfer jumping out of gear? |
Hi guys I have tail jimny 24% reduction fitted and jimny bits transfer mount kit, 2" body lift. I have enlargened the shifter hole in the body as it fouls with body lift in, but when car is under a lot of load it jumps out of 4wl into kind of a neutral/grinding between 4wl and 4wh. Any thoughts? Help? |
| Author: | Bugsta [ Mon Oct 01, 2012 6:41 am ] |
| Post subject: | Re: Jimny transfer jumping out of gear? |
Is it a ratcheting kind of sound? Perhaps it is the chain slipping. |
| Author: | bigdogdazza [ Mon Oct 01, 2012 10:06 am ] |
Nope definitely a popping and disengage noise, put it back in 4wl and fine. |
| Author: | 31zook [ Mon Oct 01, 2012 10:32 am ] |
I totally still think it torques over and knocks itself out of gear, it only did it when you were approaching full noise... |
| Author: | bigdogdazza [ Mon Oct 01, 2012 6:23 pm ] |
You reckon if I enlarge transfer shifter hole a bit and try different mounts it may cure it Josh? |
| Author: | SierraDan [ Mon Oct 01, 2012 6:37 pm ] |
stiffer mounts |
| Author: | jimny_timmy [ Mon Oct 01, 2012 7:23 pm ] |
Aren't you already running the ORA mounts Daz? |
