It is currently Fri Oct 16, 2026 7:31 am
Post Posted: Mon Oct 01, 2012 8:45 pm
cracked this wheeling on the weekend. Thoughs....
guess easiest fix is cut, replace then strenghten and brace all mounts on diff
oh and replace with rubber bushes
Post Posted: Tue Oct 02, 2012 6:50 am
Don't make the repair too strong or next time it goes (yes it will break again), it will leave a big hole in the axle tube.
Post Posted: Tue Oct 02, 2012 8:59 am
so i am guessing the diff housing metal is just as weak/thin as the brackets.
Is it possible to spread the load of where the brackets mount across a larger section of the diff somehow to prevent the whole diff ripping? or maybe diff bracing
Post Posted: Wed Oct 03, 2012 4:58 am
The diff will be fine. This happened to mine . I got some 5 mm plate and got it laser cut and welded new mounts on for both sides . That was 4 months ago and I haven't had a problem since
Post Posted: Mon Oct 08, 2012 11:29 pm
Ended up getting 2stroker to fix the tear on the diff brackets.
He welded up the torn (or tear-ed) bracket on the driver’s side (pic above) and a small crack that had started on the passenger side (Probably as a result of the damaged driver’s side). He added a small gusset to the outer side of each side's bracket (2 total). He did this as a opposed to laminating the bracket as he though the original damage was caused from a lateral force and gussets would be a better fix. Plus got him to press in some new rubber bushes that I got off ebay. Hoping rubber will put a little bit less load on the diff bracket and will give a little bit more flex compared to the poly bushes.
$200 all up for the work by 2stoker. pretty happy with the end result. Will keep you posted how it holds up after some wheeling
Vehicle: 1985 lwb sierra UTE
Post Posted: Tue Oct 09, 2012 4:51 am
That came up well
Vehicle: LJ20 LJ50
Post Posted: Tue Oct 09, 2012 5:15 am
djed wrote:
He welded up the teared bracket on the driver’s side
Was it an emo Bracket???? all teary and crying??? or was it torn???
Camels have nice toes
Post Posted: Tue Oct 09, 2012 6:14 am
:rofl: Lol
Post Posted: Tue Oct 09, 2012 6:34 am
They are normally painted black and don't ask about the owners
Post Posted: Tue Oct 09, 2012 6:38 am
Have u heard about the new grass trend.
Emo grass
It cuts it self
Post Posted: Tue Oct 09, 2012 8:04 am
haha yeah that is probably bad english. teared, replaced with torn in above post
Post Posted: Tue Oct 09, 2012 9:51 am
Better than most My post.
looks awsome thou
Users browsing this forum: No registered users and 153 guests
