It is currently Sat Oct 10, 2026 11:33 pm
Vehicle: 89 SWB zuke
Post Posted: Wed Oct 03, 2012 8:04 pm
can anyone identify and explain install of the red circled item? Came with rear wheel bearing kit (also the retainer not pictured) and the axles didnt have one installed before. I dont think its the oil seal protector, oil seal protector stays in the diff housing and just prevents you from resting axle on seal during install?
Post Posted: Wed Oct 03, 2012 8:05 pm
That is a spacer that goes between the bearing and outer axle end for a narrow track. WT sierra's have this on the bearing itself. It is not the oil seal protector. I dare say the image you have is from a WT.
Post Posted: Wed Oct 03, 2012 9:14 pm
Cheers Joe, so guess this means I have ordered the wrong kit :cry: I have a WT
Post Posted: Thu Oct 04, 2012 6:11 am
Some WT bearing kits come with that ring as an integral part of the bearing inner race.
Your kit has it seperate but is still quite usable.
Fit the backing plate then ring then bearing. Make sure the ring has the chamfered edge facing the axle flange.
Users browsing this forum: Google Adsense [Bot] and 156 guests
