It is currently Sat Oct 24, 2026 3:17 pm
Vehicle: 1972 suzuki lj20v
Post Posted: Sat Oct 06, 2012 2:15 pm
Does anyone know if lj50 big end rod bearings will work in my lj20!?? Or can someone please post the lj50 big end rod bearing part number.
Please let me know asap
Thanks!
Vehicle: LJ50V, SJ70
Post Posted: Sat Oct 06, 2012 2:38 pm
Welcome to the forum! Have a look around using the search function, there's a fair bit of info on rebuilding 2 stroke cranks.
Anyway, shorcut is:
Little end: 09263-16008
Big end: 09263-23015
Should be the same part numbers for the LJ20.
Post Posted: Sat Oct 06, 2012 4:16 pm
thanks for the welcome. The part number for the big end is different. The one I got is 09263-23001 I hope this doesnt mean that its different. Does anyone have the dimensions of the lj50 bearing? I want to find out for sure if they are the same before i order the lj50 big end bearings.
Post Posted: Sat Oct 06, 2012 4:31 pm
ok so i did some more research, I found out that the 6 and 7th digit is the id of the bearing, That means the id of the big end bearings should be the same. However I was told that the lj50 bearing is 15.7 mm wide, were as my lj20 bearing is 17.7 wide. Does this mean the lj50 bearing is 2 mm narrow and thats why it is a different part number? Can anyone confirm if the lj50 bearing is 15.7 wide?
Vehicle: LJ20 LJ50
Post Posted: Sat Oct 06, 2012 5:09 pm
My book tells me part number 09263-23001 is superseded to part number 09263-23007. My book lists part number 09263-23007 as being 1 x 09263-23005 bearing 29x47x2 brng 5x2 and 2x 09160-23010 washers so this means that the original bearings have been discountinued and replaced with a skinner bearing.
Also the rod has the part number 12161-67000 and is superseded to part number 12161-63200 ( LJ50 rod part number) so this means the LJ50 bearing outer size is correct and we just need to confirm the inner measurement now.
All info mation here taken from book part number 99924-97401 Suzuki automotive parts price price guide and iterchangeable parts listing 1997 and from part number 99000-92213 suzuki parts catlogue LJ50 printed may 1976
Camels have nice toes
Post Posted: Sat Oct 13, 2012 11:14 am
I got the bearing the other day, and the bearing is the exact same except 2mm skinnier. my crank re builder is trying to locate some shims.
Vehicle: LJ20 LJ50
Post Posted: Sun Oct 14, 2012 6:47 am
Ring suzuki and see if thy still sell these parts. part number 09160-23010. Since it is for two strokes and since suzuki still make outbaords and motorbikes they may still be current part number.
Users browsing this forum: No registered users and 87 guests
