It is currently Fri Oct 16, 2026 12:48 pm
Vehicle: 82 1ltr, 93 1.3 with 6.5's
Post Posted: Tue Oct 09, 2012 6:23 pm
Heya
Have a 93 wt zook
On the rear spring mounts there are some limiters that stop the shackles from dropping too far but is giving next to nothing flex with 2" suspension lift
Do most people cut them off or modify them or get drop shackles to get extra drop/flex in the rear
Will be puttin slightly longer shocks in so they will become the limiter then to prevent inverted shackles/damage
Post Posted: Tue Oct 09, 2012 6:34 pm
I doubt you'll gain and extra useful travel by cutting them off.
Post Posted: Tue Oct 09, 2012 6:38 pm
So no point in worryin about it for the extra bit
The rear is the main area that is stopping the flex
Post Posted: Tue Oct 09, 2012 6:42 pm
How much are you after?
Longer springs and shackles will help a lot.
Post Posted: Tue Oct 09, 2012 6:45 pm
I chopped them off and found that it made no noticeable difference
Post Posted: Tue Oct 09, 2012 7:00 pm
Just a bit more than the limiters but if they are cut off and theres no differene then my best option will be to get some drop shackles
Post Posted: Tue Oct 09, 2012 7:15 pm
:rofl:
Vehicle: X-90 + Lwb Sierra + DeVitt +++
Post Posted: Tue Oct 09, 2012 7:18 pm
Post Posted: Tue Oct 09, 2012 7:20 pm
Dont really wanna spend a lot of money on new springs nd shackles or drop shackles
Have longer shocks just seein if there was an easier nd cheaper way to get more flex outta it
Post Posted: Tue Oct 09, 2012 7:23 pm
Have you tossed the sway bar away?
Post Posted: Tue Oct 09, 2012 7:26 pm
Yeah sway bar is goneskies
Just have 2" suspension lift
Will be running commyshocks with extended lines in the front
Just want a bit more flex from the rear
Users browsing this forum: No registered users and 187 guests
