It is currently Sat Oct 17, 2026 6:23 am
Vehicle: Jimny
Post Posted: Mon Sep 03, 2012 8:23 pm
Hay guy in in despite need of info or know someone that has done a wheel bearing chance to a suzuki Jimny
front and back... Left and right
Do I need anything special etc
Please guys help
Post Posted: Mon Sep 03, 2012 8:26 pm
fronts have a read of this: http://www.bigjimny.com/images/document ... arings.pdf
rears NFI, should be similar to a sierra i guess. :?
Vehicle: Suzuki Jimny 2010
Post Posted: Mon Sep 03, 2012 8:28 pm
What year model?
Vehicle: Jimny
Post Posted: Mon Sep 03, 2012 8:34 pm
98 model
Post Posted: Mon Sep 03, 2012 8:38 pm
Yeah should be piece of cake... There's a guy in eBay that sells bearing kits for a good price...
I can give you a hand to get the rear axles etc out and I have the tool to get the front hub undone but haven't had a go at them yet. I did my rear bearings last week :)
Best way is to pull them yourself and get someone to press off and on the bearings for you
Vehicle: Jimny
Post Posted: Mon Sep 03, 2012 8:43 pm
Kool I've got all the kits...
Just need the tool
Vehicle: Jimny
Post Posted: Mon Sep 03, 2012 8:44 pm
Where did u get ur tool from???
Post Posted: Mon Sep 03, 2012 8:46 pm
I got mine from jimnybits but if you're in newie like I think you are you can save yourself $75 and I'll lend it to ya for a six pack
Post Posted: Mon Sep 03, 2012 8:49 pm
check out BenT in the business directory for wheel bearing/lock nut tool
Vehicle: Jimny
Post Posted: Mon Sep 03, 2012 8:51 pm
Yer mate pm me ur number to me please
Vehicle: Nl pajero Lwb, 98 jimny
Post Posted: Tue Sep 04, 2012 5:55 am
Not to hard a job, but without a bearing tool and press forget it.If you get stuck I am at Hamlyn Terrace and have all the above and a torque wrench. Jimny front bearings are exactly the same kit as 97 vitara swb. I done the Vitara 2 weekends ago and ordered the front kit for jimny, checked the jimny weekend just gone and both were loose not even finger tight! Replacing them this weekend!I have noticed someone on Egay selling Jimnybits gear, the bearing tool as well, handy bit of gear!
Post Posted: Tue Sep 04, 2012 7:16 am
You dont need a bearing tool. Never used one in the 5 times I had my diff apart.
Vehicle: Jimny
Post Posted: Tue Sep 04, 2012 9:30 am
Wat did u use... I'm still gunna borrow Jimny Timmy one but yer wat do u use
Post Posted: Tue Sep 04, 2012 10:04 am
You could probably use 2 screwdrivers or hammer and chisel etc but if you have access to the bearing tool this is by far the best and easiest option and also allows for precise torque settings.
Vehicle: 2003 Jimny Auto
Post Posted: Wed Oct 10, 2012 9:10 pm
I did mine without a tool. Grind off the collar, bang the new one on.
Post Posted: Wed Oct 10, 2012 10:14 pm
The tool is used on the front wheel bearings. What collar did you grind off to replace the front bearings??
BenT does sell the tool through this site, also through E-bay:
http://www.ebay.com.au/itm/Suzuki-Jimny ... 1c2bf10313
He makes his own, and is not re-selling the Jimnybits tool:
http://www.jimnybits.co.uk/shop/jimny/s ... od_46.html
The locknut is done up to 220Nm. You could possibly get it off using a hammer and chisel or screwdriver, but I doubt you'd get it done up acurately without the tool and a torque wrench.
Vehicle: 2002 Suzuki XL7
Post Posted: Thu Oct 11, 2012 6:05 am
the front Jimny tool is very simalar to the Vitara tool, have a look at my thread and see what ur in for, its piss easy, but if trying to replace bearings in the front wheel hubs, have no idea, when i received the front hubs it says its a non servicable item and bearing are preset and not removable. Changing the full hub is a heck of alot easier than trying to push the bearings out of them.
viewtopic.php?f=5&t=36274&p=664288#p664288
Post Posted: Thu Oct 11, 2012 6:25 am
Yeah sorry I was thinking rear, i have never done front :oops:
Users browsing this forum: Google [Bot] and 258 guests
