It is currently Tue Oct 06, 2026 8:53 pm
Post Posted: Tue Dec 23, 2008 4:05 pm
Helloo good peoples of AUSZOOKERS, I am hoping that one of you smart people may have come across a noise like this one before. 8O We thought it may have been from the front shaft. The slip joint has some movement but have seen much worse. Any way we have fitted a new slip yolk but have not tried it yet. Transfer has no metal in oil. Give it a listen and tell us what you think. BTW this is in Zookenator's bus.
Vehicle: MY2019 Jimny
Post Posted: Tue Dec 23, 2008 4:10 pm
CV?
Post Posted: Tue Dec 23, 2008 4:25 pm
Should also mention that this is with hilux diffs, ARB air locker but not turned on. front diff seems to jerk when noise happens
Post Posted: Tue Dec 23, 2008 4:32 pm
uni, maybe
Post Posted: Tue Dec 23, 2008 4:51 pm
front output shaft in tcase?
Post Posted: Tue Dec 23, 2008 5:04 pm
sounds just like the uni's in my old car. do they bind when flexing?
if so the flog out really quick.
could also be a stuffed spring bush
Post Posted: Tue Dec 23, 2008 5:17 pm
I was wondering about the output shaft noise myself. Have not heared it before so dont know. Transfer is only very low k's new from the states though!
Post Posted: Tue Dec 23, 2008 5:46 pm
I reckon it is a CV still...
Post Posted: Wed Dec 24, 2008 1:57 am
Thanks Jon!! Your a champ ;) The drivers side cv has been clicking on full lock.. but its still working. When it happens, the vehicle "shudders". The unis havent been binding up.. im running late model lux unis which have plenty of travel. Like Jon mentioned, the transfer is fairly new still.. 6.5:1 from low range off road. It hasnt got the heavy duty front output shaft. Drained the transfer oil.. no signs of metal (thank god) Spring bushes are still fairly new.. replaced them when i did the conversion. I thought it was the front shaft, as it had heaps of slop in the slip yolk. If i left the hubs in.. and went down the road (>50 kph for eg).. it would start getting this real horrible slapping noise from the slip yolk! Jon has fixed the shaft up for me, will be putting it back in t'row and trying it.
Post Posted: Sun Dec 28, 2008 6:33 pm
Just for interest sake, it was the slop in the front shaft causing that noise!! All fixed now :D Thanks for your help jon!
Post Posted: Mon Dec 29, 2008 12:58 pm
:woohoo: , Sorry missed the weekend. You know how family are :roll:
Users browsing this forum: Google [Bot] and 203 guests
