It is currently Mon Oct 26, 2026 6:05 am
Post Posted: Sun Oct 14, 2012 2:06 pm
I just replaced the distributor o ring and the rocker cover gasket on my 91 sierra and now the car barely starts and can't go above 1500 revs. I haven't touched anything else what could be wrong?
Vehicle: Sj51t
Post Posted: Sun Oct 14, 2012 2:08 pm
Is timing ok?
Sookie wrote:
Is timing ok?
No
Post Posted: Sun Oct 14, 2012 2:10 pm
well it was running perfectly before and I haven't moved anything
Post Posted: Sun Oct 14, 2012 2:26 pm
Did you mark everything for the same position when reinstalling the distributor? your probably a tooth out on the dizzy gear.
Post Posted: Sun Oct 14, 2012 2:29 pm
Yes thats what I didn't do now I get to try hand fix the timing. Thanks guys
Post Posted: Sun Oct 14, 2012 2:44 pm
Try turning dizzy 180 degrees
Post Posted: Sun Oct 14, 2012 2:45 pm
yes you have, you're a tooth on the dizzy out.
It will be mostly trial and error now to get it right.
Post Posted: Sun Oct 14, 2012 4:29 pm
Fixed it thanks guys:)
Users browsing this forum: No registered users and 237 guests
