http://auszookers.com/forum/
Clutch supplier - Brisbane
http://auszookers.com/forum/viewtopic.php?f=5&t=36300
Author:  Damo [ Thu Oct 11, 2012 11:23 pm ]
Post subject:  Clutch supplier - Brisbane
Exedy are all the rage apparantly. I looked at the pink Excedy HD, a bit pricey? Is it really necessary?
I need one pretty quick-ish.
Author:  31zook [ Fri Oct 12, 2012 12:57 am ]
Post subject:  Re: Clutch supplier - Brisbane
I always ran the $180 auto barn clutch, 2-3 years on each and still good :-)
Author:  TZAR [ Fri Oct 12, 2012 4:57 am ]
Get an old one rebuilt with some super bits added. Come on you know you want too. You cant get over those roundabouts and kerbs with just a standard clutch now can you.....
http://www.npcperformance.com.au/index.html
Author:  atari4x4 [ Fri Oct 12, 2012 9:18 am ]
didn't Mr Knife like the clutch industries ones?
Author:  Mickc [ Fri Oct 12, 2012 9:51 am ]
Direct Clutch at Albion modified a excedy clutch pressure plate by adding extra spacer ring.
Increasing pressure applied to plate without extra tension on clutch cable, suppose to be similar
set-up to HD Excedy unit. Cost $200 from memory
Author:  want33s [ Fri Oct 12, 2012 5:38 pm ]
I recommend Direct Clutch.
Helped me out with my Toyota-Suzuki clutch/pressure plate setup in my buggy.
Author:  Scrawny [ Fri Oct 12, 2012 5:40 pm ]
I've never had an issue with CI ones
