It is currently Sat Oct 24, 2026 7:44 am
Vehicle: Suzuki Vitara JLX 1991
Post Posted: Fri Oct 12, 2012 10:27 pm
Hi Folks,
Suzuki Vitara 1991
JLX model
1.6 litre Carby
SE416 Model
G16A
Just purchased this car 4 weeks ago.
So i was caught in heavy traffic last weekend for around 45 minutes moving very slowly and a lot of idling behind a grid locked traffic jam.
After about 45 mins I noticed when the traffic flow started to the move the clutch pedal got very soft and it was extremely hard to get into first gear. A few times it would not go into gear at all!
I rolled up on onto the shoulder of the freeway and BOOM changed into first gear and I checked all the gears including first and it was shifting perfectly again. OFf I went with no worries with shifting it was smooth.
I drove another 20 minutes and got caught in a shopping centre car park behind cars on a ramp and as I took off again the clutch went spongy and i couldn't put it in first gear. I hopped out and pushed the car over to the side. I got back in the car and everything was back to normal again and shifting fine?? WTF?
I drove home(20 mins) without any further trouble.
That was 2 weeks ago and I haven't had any trouble since. But then again My work is only 5 kms from my house so I havent taken it on any long drives since that happened except for local shops etc
The clutch was changed 6 months ago according to the owner. When the mechanic was changing my leaking tail shaft seal he did mention the clutch seemed new and may have been a heavy duty clutch due to it biting a bit when taking off when he drove it.
Also I am guessing the clutch on this model is a mechanical and not hydraulic with a slave and master cylinder?
I am just worried as I am making a long 900km trip in early November out bush and dont want to have any troubles caught in a remote area. the trip is over 2 days stopping off in several places so it wont be 900km in one straight run.
I am enjoying this new little 4WD rig
any tips?
Cheers fellas!
Post Posted: Fri Oct 12, 2012 10:54 pm
welcome to AZ Jason, nicely written first post... you'll do well around here!
yeah, it's a cable clutch & they're a pretty common thing to have fail. especially if it's never been replaced & a new clutch fitted more so if it's heavy duty. so i'd definitely be having a look at the cable, the other area that has shown the odd clutch problem is the pedal box assembly where the clutch pedal pivots or the clutch pedal bending from a stuffed clutch cable, clutch poorly adjusted etc
not sure if the one that suzistore list is non gen or not... but i'd be hunting down a genuine suzuki one. http://www.suzistore.com.au/shopdisplay ... ANSMISSION
Vehicle: LJ50V, SJ70
Post Posted: Sat Oct 13, 2012 3:21 am
Not sure if the one that suzistore list is non gen or not... but i'd be hunting down a genuine suzuki one. http://www.suzistore.com.au/shopdisplay ... ANSMISSION
Suzistore use a letter code at the end of the Suzuki Part Number.
N = Non-Genuine
M = Maruti
G = Suzuki Genuine Parts.
It looks like the Vit clutch cable is made by Maruti?????
Post Posted: Sat Oct 13, 2012 5:32 pm
N = Non-Genuine
M = Maruti
Ok thanks. Might get it replaced just in case it has issues. Dont want it having troubles on the road. :D
Users browsing this forum: No registered users and 193 guests
