It is currently Fri Oct 30, 2026 5:14 am
Vehicle: 90 hardtop and 89 soft top
Post Posted: Fri Oct 12, 2012 6:41 pm
Tomorrow at the 4wd show I'm expecting to pick up aload of stuff and one of them is a duel battery system, first is there any recommendations on a good automatic system to run that isn't going to burn a hole in my pocket and what amp does the factory alternator put out. FYI I am running a winch spotties light bar and very big sound system, we it will be installed after I get these battery's sorted. Any help on brands and products would be appreciated.
Post Posted: Fri Oct 12, 2012 8:13 pm
Unless there are swords involved it is 'dual'.
Get a Rotronics kit or a RedArc unit.
Post Posted: Fri Oct 12, 2012 8:43 pm
Red arc is expensive isn't it? And I've never heard if rotronics? Would they have stand?
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Oct 12, 2012 9:13 pm
You have a pm ;)
Post Posted: Sat Oct 13, 2012 9:01 am
redarc are available for 90 bucks..... if your putting a "very big" sound system in, i would think the isolator is the least of your cost concerns.
MY BUILD THREAD HERE!!!!!
Vehicle: 02 Suzuki Jimny
Post Posted: Sat Oct 13, 2012 8:22 pm
I'd say just get a Projecta Kit mate... comes with everything you need exc. battery and they do alright.
TF
Post Posted: Sat Oct 13, 2012 9:04 pm
Mine is a Rotronics Weekender, totally automatic, I've been running it for about five years and it's been trouble free.
Vehicle: 11 GV3 diesel
Post Posted: Sun Oct 14, 2012 7:45 pm
I run an abr sidewinder kit, had it for a year, cant complain. Look them up
Vehicle: SJ80, SE416
Post Posted: Sun Oct 14, 2012 9:24 pm
What are you running off the auxilliary battery - you'd probably run your lightbar and sound system off the cranking battery (the engine is running while these are) and keep the auxilliary as a reserve or run a fridge off it overnight.
Can you solder? You can't beat $22 - YES - ONLY TWENTY-TWO BUCKS PLUS SHIPPING! A work colleague of mine installed one of these in his Patrol. I'll be putting one of these in my Vit. All you need is a small jiffy box and some cable and fuses to go with it.
http://secure.oatleyelectronics.com/files/K227webnotes.pdf
http://secure.oatleyelectronics.com//product_info.php?products_id=270
AFAIK - WT Sierra alternator is 45A, Coily & 1.6 Vit is 50A.
Post Posted: Mon Oct 15, 2012 5:05 am
Have a look at the EL falcon alternator thread in good tech.
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Users browsing this forum: Google [Bot] and 1405 guests
