http://auszookers.com/forum/
1.3l transfer case oil?
http://auszookers.com/forum/viewtopic.php?f=5&t=36338
Author:  haurp00ned [ Sat Oct 13, 2012 5:13 pm ]
Post subject:  1.3l transfer case oil?
hey guys i was just wondering how do you drop out and change the oil in the transfer case? i cant seem to locate the buds? cheers.
Author:  zukmeista [ Sat Oct 13, 2012 5:39 pm ]
Post subject:  Re: 1.3l transfer case oil?
Drain plug is at the bottom, filler bung is on the left side about halfway up. The bungs are designed for a 10mm square drive, but you may get away with a 3/8 ratchet.
Author:  haurp00ned [ Sat Oct 13, 2012 5:47 pm ]
yeah i did think that was them cheers, and also how much oil does it take? and what do use recommend cheers.
Author:  zukmeista [ Sat Oct 13, 2012 6:00 pm ]
Just under a litre. I use Castrol EPX 80/90.
Author:  want33s [ Sat Oct 13, 2012 7:05 pm ]
EPX 80W90 contains Sulphur and Phosphorus which can attack bronze components.
Definitely not the recommended oil for Sierra transfer case.
Use VMX-M 75W-85....
http://www.datateck.com.au/lube/castr_au/default.asp
Author:  Joshyboy26 [ Sat Oct 13, 2012 7:09 pm ]
what is bronxe in a tc? just for anyone looking at this thread haha
Author:  want33s [ Sat Oct 13, 2012 7:15 pm ]
The counter shaft washers.
Author:  Joshyboy26 [ Sat Oct 13, 2012 7:19 pm ]
ah yes
Author:  kristov [ Sun Oct 14, 2012 10:17 am ]
would EPX80-90 be alright to run in my jim transfer case?
Author:  atari4x4 [ Sun Oct 14, 2012 10:20 am ]
i use this as a guide http://www.datateck.com.au/lube/castr_au/
Author:  want33s [ Sun Oct 14, 2012 10:21 am ]
I wouldn't...
Castrol ONLY recommend VMX-M for Suzuki transfers.... If EPX was OK I'm sure they'd list it too.
Author:  kristov [ Sun Oct 14, 2012 10:27 am ]
thanks atari :D i think ill get a big bottle and change my gearbox to VMX looks like a more quality oil
