It is currently Sat Oct 31, 2026 2:39 pm
Vehicle: sj80 1996
Post Posted: Sun Oct 14, 2012 10:02 pm
Well I was wondering if anyone has fitted these yet and if they have increased the spring lift over 2" without damaging other suspension components?
As all I have read so far with coilys suspension dramas is broken or bent radius arms.
So id love to know if this will even allow and inch or two more lift to possibly allow 3"-4".
Cheers,Jake.
Here's the link.
http://store.snakeracing.com.au/~snaker ... f24ba8c4ac
Vehicle: SJ80, SE416
Post Posted: Sun Oct 14, 2012 10:11 pm
Those aftermarket arms will only correct castor from a large lift - you still need to source struts and springs to do a big lift. Lifts above 40mm are uncommon on a coily because these are no off-the-shelf struts available to do the lift with.
Personnaly, i'd just stick castor correction bushes in the standard arms - IMO the standard arms are strong enough - stronger than the mounts on the diff even. In my experience the bent arm I have came with a very broken diff and equally broken chassis - they are hardly weak.
Vehicle: sj80 1996
Post Posted: Sun Oct 14, 2012 10:32 pm
Thanks for the quick detailed reply.
It's a shame with the coilys, hopefully something else will pop up then.
Thanks for the suggestion of castor correctors alot cheaper option to.
Post Posted: Mon Oct 15, 2012 8:53 am
Just make new diff mounts
Its going to rip off anyway might as well move it around a bit while ur there
Users browsing this forum: No registered users and 248 guests
