It is currently Sun Nov 01, 2026 7:37 am
Vehicle: On the lookout
Post Posted: Sun Oct 07, 2012 4:42 pm
Jimney started whinning. Slowly getting louder. Also a rattle become noticable in forth and to a lesser extent in fifth gears at lower rpms. Whining noise is noticable at higher speeds, 50kph+. No loss of performance.rattle noise dissapears when off throttle. Whining noise constant at higher speeds, doesn't go away in neutral when coasting or change tone. So I suspect its not engine, probably drivetrain.
Post Posted: Sun Oct 07, 2012 4:45 pm
glass gearbox
Post Posted: Sun Oct 07, 2012 6:30 pm
Check ya jack shaft.
Post Posted: Sun Oct 07, 2012 6:37 pm
X2
Post Posted: Sun Oct 07, 2012 8:55 pm
Thanks. I'll probably take it to someone, just want to have a basic ideas of what it might be so I don't get a bum steer.
Post Posted: Sun Oct 07, 2012 8:59 pm
Just grab the shaft and try to wiggle the UNI joints. If there is more then .5mm of movement, repack or replace.
Also, knock your tcase into neutral and try then, it won't load it up, but it could help...
Post Posted: Sun Oct 07, 2012 11:00 pm
not all jimny t-cases have neutral........
MY BUILD THREAD HERE!!!!!
Post Posted: Wed Oct 10, 2012 1:52 pm
glass gearbox
Dead Gearbox. 10 points to atari4x4
Post Posted: Wed Oct 10, 2012 3:48 pm
Armsup gold star for me.... der Hillbilly wuz write, Jimney's r piss week :oops:
Post Posted: Thu Oct 11, 2012 5:41 am
well gearbox has lasted 66,000 km from new. At least it lasted 10,000km longer then the rear driveshaft. 8O. its not just a whine anymore. In two weeks its gone from a whine to a full "I'm preparing to explode" rattle.
Post Posted: Thu Oct 11, 2012 11:16 am
Hmmm... Do you think the 1.8L caused its death or even sped it up a little.
You've got me worried now! I've got a slight leak from the rear of the gearbox that's been there for ages. I should probably look into it further. :oops:
Post Posted: Thu Oct 11, 2012 11:59 am
didn't monley blow up a box with very low kms too?
Vehicle: Suzuki Jimny 2010
Post Posted: Thu Oct 11, 2012 12:23 pm
Na not Monley, but I think it was one of the WA boys
Post Posted: Fri Oct 12, 2012 6:39 pm
It would be nice to dream that my M18 had enough power to blow the gearbox, but I suspect that monstrous power house of an engine needs about 30 more ponies to get anywhere near stressing the box.
It's most definately the sandy water I sat in for about 45 minutes back in January. The rear diff oil looked the same as what I just drained from the gearbox, so rear diff is going to need some work possibly, unless I caught it just in time. (excuse for a rear locker? :)
The slight leak from the rear of your gearbox will require a new drive shaft number 2 (gearbox to transfer). That's what suzuki did to fix mine. Now that I'm tackling the gearbox myself I'm realising what an easy little job it was to replace shaft 2 that my suzuki dealer charged an exhorbitant price for.
Post Posted: Tue Oct 16, 2012 9:52 am
Don't know if anyone's still interested in this thread, but basically it the Rear Main Bearing in the gearbox has gone, and I caught it in time not to damage any gears.
The Gearbox and Diff specialist reckons it has little to do with the dirty oil since he just fixed the same issue in another jimny, he suspects it's just litterally worn out. Jimny gearboxes are truly crap as it's now the second one he has attended to in the space of 1 month, both having less then 100,000k's on the clock.
Post Posted: Tue Oct 16, 2012 9:57 am
glass gearboxs & they push over easy, any other distinguishing features :lol:
wonder if it's a quality control issue with the bearing suppler, i'd say monleys started off like this but ended up destroying the whole box.
Post Posted: Tue Oct 16, 2012 10:02 am
Must be only vvt boxes that you hear breaking
Users browsing this forum: No registered users and 377 guests
