It is currently Tue Oct 06, 2026 7:57 pm
Post Posted: Wed Dec 31, 2008 2:11 pm
What are the differences between g13 and g16 clutch/flywheels?
Post Posted: Wed Dec 31, 2008 2:16 pm
G16 is 25mm bigger diameter
G16 Flywheel is bigger, as well as being a lot thicker and heaver
G16 throwout and the way it activates is pretty similar to 1.3 ones
depending on which sierra one you have the spigots interchange and I think the splines may be similar
I dont think you could sneak a 1.6 flywheel and clutch into a sierra bellhousing though
Post Posted: Wed Dec 31, 2008 2:38 pm
So the clutch plate (eg, the one with the friction material on it) is 25mm bigger as well as the flywheel? Considering when you do a 1.6 swap into a Sierra the starters interchange, I thought that the flywheel would be the same overall diameter.
Post Posted: Wed Dec 31, 2008 2:51 pm
no cause the starter bolts in in relation to the gearbox not the block :wink:
Post Posted: Wed Dec 31, 2008 3:43 pm
Ahhh that will explain it. So using the 1.6 flywheel wont work unless you use the 1.6 transmission.
What about the tranny input splines? I've never seen a Vit manual in the flesh before.
Post Posted: Wed Dec 31, 2008 4:04 pm
they may be the same, exedy site might say whats what
1.6 bellhousing comes off too, perhaps you could adapt it to the sierra box
or get Joe to chop one down :)
Post Posted: Wed Dec 31, 2008 4:34 pm
yes my children.....they are the same splines....on the 1.6 that is...
Post Posted: Wed Dec 31, 2008 5:30 pm
Schweet, thanks Dad :mrgreen:
Post Posted: Wed Dec 31, 2008 6:49 pm
dad?......now you makin it sound kinky :wink:
Post Posted: Wed Dec 31, 2008 7:22 pm
you started it :P
Users browsing this forum: Google [Bot] and 262 guests
