| 1.6 & 1.3 clutch http://auszookers.com/forum/viewtopic.php?f=5&t=3678 |
| Author: | Damo [ Wed Dec 31, 2008 2:11 pm ] |
| Post subject: | 1.6 & 1.3 clutch |
What are the differences between g13 and g16 clutch/flywheels? |
| Author: | royce [ Wed Dec 31, 2008 2:16 pm ] |
| Post subject: | Re: 1.6 & 1.3 clutch |
G16 is 25mm bigger diameter G16 Flywheel is bigger, as well as being a lot thicker and heaver G16 throwout and the way it activates is pretty similar to 1.3 ones depending on which sierra one you have the spigots interchange and I think the splines may be similar I dont think you could sneak a 1.6 flywheel and clutch into a sierra bellhousing though |
| Author: | Damo [ Wed Dec 31, 2008 2:38 pm ] |
royce wrote: G16 is 25mm bigger diameter
G16 Flywheel is bigger, as well as being a lot thicker and heaver G16 throwout and the way it activates is pretty similar to 1.3 ones depending on which sierra one you have the spigots interchange and I think the splines may be similar I dont think you could sneak a 1.6 flywheel and clutch into a sierra bellhousing though So the clutch plate (eg, the one with the friction material on it) is 25mm bigger as well as the flywheel? Considering when you do a 1.6 swap into a Sierra the starters interchange, I thought that the flywheel would be the same overall diameter. |
| Author: | royce [ Wed Dec 31, 2008 2:51 pm ] |
no cause the starter bolts in in relation to the gearbox not the block |
| Author: | Damo [ Wed Dec 31, 2008 3:43 pm ] |
royce wrote: no cause the starter bolts in in relation to the gearbox not the block
Ahhh that will explain it. So using the 1.6 flywheel wont work unless you use the 1.6 transmission. What about the tranny input splines? I've never seen a Vit manual in the flesh before. |
| Author: | royce [ Wed Dec 31, 2008 4:04 pm ] |
they may be the same, exedy site might say whats what 1.6 bellhousing comes off too, perhaps you could adapt it to the sierra box or get Joe to chop one down |
| Author: | joeblow [ Wed Dec 31, 2008 4:34 pm ] |
yes my children.....they are the same splines....on the 1.6 that is... |
| Author: | Damo [ Wed Dec 31, 2008 5:30 pm ] |
joeblow wrote: yes my children.....they are the same splines....on the 1.6 that is...
Schweet, thanks Dad |
| Author: | joeblow [ Wed Dec 31, 2008 6:49 pm ] |
dad?......now you makin it sound kinky |
| Author: | Damo [ Wed Dec 31, 2008 7:22 pm ] |
joeblow wrote: dad?......now you makin it sound kinky you started it joeblow wrote: yes my children.....
