| sierra feels like its locking up ?? http://auszookers.com/forum/viewtopic.php?f=5&t=36892 |
| Author: | rob45x [ Mon Nov 05, 2012 6:57 pm ] |
| Post subject: | sierra feels like its locking up ?? |
Hey guys. The first time ive checked my sierra into 4H today and locked the front hubs in. But when i make a turn the wheels start locking up and gets tight/jammed. Now i know what lockers are etc and how diffs work but im unfamiliar with 4wd mode as ive never used it. Any help or ideas/ is this normal when in 4wd mode? cheers in advance! |
| Author: | reeceh [ Mon Nov 05, 2012 6:59 pm ] |
| Post subject: | Re: sierra feels like its locking up ?? |
Are you fully engaging the hubs? |
| Author: | SierraDan [ Mon Nov 05, 2012 6:59 pm ] |
on tar? |
| Author: | rob45x [ Mon Nov 05, 2012 7:01 pm ] |
yes the hubs are fully engaging and yes on tar |
| Author: | atari4x4 [ Mon Nov 05, 2012 7:06 pm ] |
not a good idea using 4wd on high traction surfaces |
| Author: | rob45x [ Mon Nov 05, 2012 7:08 pm ] |
ok. so i stuffed up lol. wont happen again |
| Author: | JrZook [ Mon Nov 05, 2012 7:09 pm ] |
ON tar ouch!!! What you are experiencing is wind-up. Not good for any of the drive train! 4x4 is only to be used on low traction surfaces where the tires will slip, not tar! |
| Author: | rob45x [ Mon Nov 05, 2012 7:13 pm ] |
geez lucky i didnt break anything. Its just that i have a slight growling noise coming from underneath backing off and on accelerator and thought it might be the rear diff. So i disconnected the rear tail shaft and drove it home on the front diff in 4wd mode. But massive vibration when i done that. so pulled over and slipped the rear shaft back on. No vibration in 4wd. really lucky i didnt stuff anything |
| Author: | Zook_Fan [ Mon Nov 05, 2012 8:42 pm ] |
You shouldn't have any vibrations running with the rear shaft out and in 4H. It sounds like you have other problems as well |
| Author: | rob45x [ Mon Nov 05, 2012 8:48 pm ] |
yeah it was weird. didnt think it should make a difference if i have the rear shaft in or out in 4wd. |
| Author: | atari4x4 [ Mon Nov 05, 2012 9:11 pm ] |
jack shaft uni's |
| Author: | rob45x [ Mon Nov 05, 2012 9:17 pm ] |
but the jack shaft is always spinning whether the front or rear shaft is in |
| Author: | JrZook [ Mon Nov 05, 2012 10:53 pm ] |
Front shaft unis. Probs haven't been used for a while and are stiff/semi seized |
| Author: | Zook_Fan [ Mon Nov 05, 2012 10:54 pm ] |
Did you disengage the hubs when you put the rear shaft back in? |
| Author: | rob45x [ Tue Nov 06, 2012 5:14 am ] |
At first I left them engaged. And drove it in 4wd with no vibration |
