It is currently Sat Oct 31, 2026 2:37 pm
Vehicle: 99 JLX Suzuki Jimny
Post Posted: Mon Nov 05, 2012 8:29 pm
Ihave a 99 jimny and it takes about 30 mins on a hot day for the A/C to start to get pretty cool, is this normal ?
Post Posted: Mon Nov 05, 2012 8:34 pm
No. Go and get it regassed. Also check there's no blockage in the condensor and the electric fan is working
Post Posted: Mon Nov 05, 2012 8:37 pm
30 min, I would set my car on fire if the AC took that long to work. My cars know that it isn't a idle threat either :wink:
Post Posted: Mon Nov 05, 2012 9:17 pm
:rofl: :rofl: Armsup its funny couse its true
 Profile YIM
Post Posted: Mon Nov 05, 2012 9:44 pm
lol...ok, I can't really stand the heat and if it could freeze me I would really like it, the fan works, how do I check for a blockage in the evaporator ?
Post Posted: Tue Nov 06, 2012 5:04 am
Have a look through it from the front, you may need a torch. I'm talking about grass seeds and mud blocking air flow through it
Post Posted: Tue Nov 06, 2012 5:50 pm
ok, I hsve no idea where the eveaporator is located, not really knowledgable about any of the a/c
Post Posted: Tue Nov 06, 2012 5:53 pm
Looks just like a smaller version of a radiator and sits in front of the radiator
Post Posted: Tue Nov 06, 2012 8:18 pm
ok, yea, that is clean I try to make sure of it, I wash it with the hose
Post Posted: Tue Nov 06, 2012 8:40 pm
yeah get it regassed, with proper r134a and a dye, a proper AC tech should give you a good idea on the state of the system when he does it
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Tue Nov 06, 2012 8:46 pm
its called a condensor. Evaporator is under the dash ;)
Post Posted: Tue Nov 06, 2012 8:48 pm
and you can pressurize the system with the right fittings before you re-gas it to check for leaks etc
Post Posted: Wed Nov 07, 2012 5:22 am
Check your a/c belt is tight too. But along with everyone else, go and get it regassed and leak checked. Should be done every twelve months (even though I've never done either of my cars)
Post Posted: Wed Nov 07, 2012 8:22 pm
Thanks for the help, I will book it in
Post Posted: Wed Nov 07, 2012 9:19 pm
Also note an A/c service might cost a lil more now due to the Rize in price of r134a gas (about a 300% increase)
Post Posted: Thu Nov 08, 2012 5:30 am
Yep, you're right. I shouldn't post after 9pm :roll:
Post Posted: Thu Nov 08, 2012 6:36 pm
Thats crimnial
Vehicle: 1.6 SJ80
Post Posted: Thu Nov 08, 2012 6:52 pm
Just wondering how you suggest to pressurise the system? I usually apply vacuum and leave for an hour or so while the guages are on and look for a leak.
Users browsing this forum: No registered users and 239 guests
