Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
liama
Vehicle: 2012 Grand Vitara
 Posted: Wed Nov 07, 2012 10:34 pm |
Ive been doing allot of research over the various forums recently, and cant seem to find any new shape grand vitaras with Sunraiser style rims on them. Does anybody know if it is possible to get these rims for the NGV? I plan on having the stock tyres for everyday use, then a set of A/T tyres or M/T tyres for when i go off road. Really keen for sunraisers though !:p
303zuke
Vehicle: LJ50V, SJ70
 Posted: Wed Nov 07, 2012 11:10 pm |
I don't think anyone has made them. You might be able to get some as a special order.
The wheels needs to be at least 16" to clear the front caliper. The bolt pattern is 5 on 114.3 (4.5") which is the same as Ford Falcon or Territory, or late Jeep. And the offset is positive. There is no off the shelf Sunraysia wheel in this combo, although you could come close with some factory alloys, and a bit less offset (for a wider track) wouldn't go astray.
I'd try the wreckers for a cheap set of AUII Falcon alloys and fit them up to see how they go. Would be cheaper than special Sunnys. And I'm sure the wreckers would almost give away some stock Falcon Steelies.
liama
 Posted: Wed Nov 07, 2012 11:24 pm |
Cheers for the info, i didnt realise falcon or territory rims would fit!. i might see if i can find some stock factory alloys from gum tree or somthing.
zooks4life
Joined: Thu Jun 10, 2010 8:36 pm Posts: 477 Location: Parkes, NSW
Vehicle: 11 GV3 diesel
 Posted: Wed Nov 07, 2012 11:27 pm |
Jester
Joined: Fri May 08, 2009 11:30 pm Posts: 726 Location: Adelaide
 Posted: Thu Nov 08, 2012 7:40 pm |
well with the ford falcon rims fitting there should be some sunnies about, the BA-BF RTV had an option for sunraysias even from factory
suzkboy
Joined: Mon Oct 12, 2009 10:30 pm Posts: 270 Location: South Australia
 Posted: Thu Nov 08, 2012 8:02 pm |
2wd hilux is 5x114.3 along with any 5 stud nissan, 90's Mazda and 5 stud toyota so you should be able to find a wheel that u like.
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 452 guests
