Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
Posted: Wed Dec 31, 2008 12:38 am
hey guys
can anyone who has tried it help me
does ruf work ok on a spoa short wb zook??
it has a 65 mm chassis extension already so I can do a proper ruf but i worried it may be too soft.
the springs id like to use are now flat rancho 2"lift
also how much would it move my diff forward on a full ruf?
cheers andrew
There is nothing wrong with putting longer springs in the front, SPUA or SPOA. How soft it is comes down to spring rate, which is effected by the length of your spring, but also width, thickness of leaves and number of leaves. You should be able to put the rear springs in the front then tweak them if you find it's too soft.
From memory putting the RUF will put your diff forward about and inch. With SPOA and 35s you're still going to have to do more to stop the tyres chewing your gaurds.
Users browsing this forum: No registered users and 158 guests
