http://auszookers.com/forum/
Diff perch spacing
http://auszookers.com/forum/viewtopic.php?f=5&t=36992
Author:  anDy86 [ Fri Nov 09, 2012 2:47 pm ]
Post subject:  Diff perch spacing
Hi fellow auszookians,
I have started my wt diff conversion on my LWB.
While welding on the front perches with a mate we grinded off the markings I left for perch spacing.
When I test fitted this they are about 5ml too wide compared to the original NT spacing.
Am I going to run into any troubles with this or will it be fine?
Thanks,
Andrew
Author:  Fatzook [ Fri Nov 09, 2012 2:50 pm ]
Post subject:  Re: Diff perch spacing
5mm is within factory tolerance. May even be more acurate than the OEM perches. :wink:
Author:  anDy86 [ Fri Nov 09, 2012 2:57 pm ]
Haha thanks fatzook! My welder mate loved your perches
Author:  dono1 [ Fri Nov 09, 2012 5:22 pm ]
Same with the guy that welded mine!
Author:  Daves4wd [ Fri Nov 09, 2012 8:22 pm ]
Good man Andy before you know it it'll be done
Author:  KEENSY85 [ Sat Nov 10, 2012 5:42 am ]
There surprisingly a lot of work in the nt to wt conversion hey:) I I think it will be worth, it I'm in the middle of mine atm
