It is currently Sun Oct 25, 2026 11:26 am
Post Posted: Fri Nov 09, 2012 5:31 pm
Hi guys... Anyone bought one? Or have an opinion about it?
http://www.lowrangeoffroad.com/index.ph ... radle.html
I'm trying to decide whether I'll be better off simply purchasing one of these or getting a mate to help fabricate a cradle & incorporate a roctoy & heavy duty mounts..
Im currently running 6.5's & 35's.... Thoughts/opinions? Cheers!
Post Posted: Fri Nov 09, 2012 5:56 pm
Great bit of gear. But there can be a huge wait for them. Last I checked it was a 4 month delay. :cry:
Post Posted: Fri Nov 09, 2012 6:03 pm
Ah...fick.. Cheers mate.
Post Posted: Fri Nov 09, 2012 6:06 pm
Werent they released a couple of days ago Pete?
Post Posted: Fri Nov 09, 2012 8:24 pm
could go the mighty Kong Case and weld a Ring on if u really wanted
Post Posted: Fri Nov 09, 2012 8:42 pm
Yeh I saw that's what afew people have done.. Isn't this new cradle pretty similar to that setup?
Post Posted: Fri Nov 09, 2012 8:49 pm
The new one is better as it picks up another mount.
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat Nov 10, 2012 5:32 am
Could u just get ur original mounts and I and just plate them (increasing thickness) and mount a rock toy ring to it?
Post Posted: Sat Nov 10, 2012 5:37 am
Could u just get ur original mounts and I and just plate them (increasing thickness) and mount a rock toy ring to it? Justcruising makes awsome tcase mounts also u could easily ad a rocktoy ring to it (I think someone road here said that he can get rocktoy rings) Fatzookster might have an option as well since he's back on deck :)
Post Posted: Sat Nov 10, 2012 11:38 am
Does the ring in the new mount work pretty much the same as a roctoy?
Post Posted: Sat Nov 10, 2012 12:21 pm
cant really see the need for such a HD mount JMO
Post Posted: Sat Nov 10, 2012 12:38 pm
Really?
Post Posted: Sat Nov 10, 2012 12:56 pm
Horses for courses.
Post Posted: Sat Nov 10, 2012 2:06 pm
Yep. My bad. The link didn't load, so I assumed it was the red cradles that they sell. My bad.
Post Posted: Sat Nov 10, 2012 3:24 pm
You can and when I did this it started ripping the bolts out of the case and bending the chassis mounts.
Post Posted: Sat Nov 10, 2012 3:59 pm
What specs? What size tyres and reduction gears?
Would u have rathered u didn't run a rocktoy ring, or just plated the original mounts?
What would u have done differently? :)
Post Posted: Sat Nov 10, 2012 5:03 pm
That was on 33's, 5.14 TC gears and 5.12 diff gears, thickened pass side arm and gusseted drivers side arm, raised case with solid mounts and driving nothing but rocks.
Differently ? I would have used RHS to raise the factory rubber mounts, or Just_cruzin's mounts, or added the extra rubber mount to the pass side like someone posted on here, this would possibly have been enough. The stock arms start bending once you are twin locked on 31's or bigger, with gearing and on high traction terrain. The Roctoy ring does help some but as with any mod it simply moves the problem to somewhere else in the driveline and the chassis mounts and case bolts become the next weakest point from my experience.
Post Posted: Sat Nov 10, 2012 7:38 pm
I reckon It is solid mounts that kill Sierra transfer cases.
Post Posted: Sat Nov 10, 2012 10:18 pm
X2.
You need a fusable link. Otherwise the case or gear faces will become the next best thing. :cry:
Post Posted: Sun Nov 11, 2012 12:49 am
Have never killed a case it was just the arms and mounts that bent with the solid mounts. However I ran solid mounts for a few years and only had to straighten the arms/mounts 2 or 3 times in that period, so it wasnt a 'huge' issue when I was on 33's with 38's though I was lucky to get 1/2 an hour out of it before they would twist to the point the input shaft was starting to come through the floor. But by the same token there has been a few threads over the years of people chewing through the rubber mounts every trip, arms are easy enough to straighten were as the rubber mounts tend to be ripped in half.
Post Posted: Sun Nov 11, 2012 4:01 am
I've been waiting nearly 5 months for my transfer cradle from lowrange (should be here next week) and now they release their own cradle which looks like a better design for roughly the same money :idea: :deadhorse:
Post Posted: Sun Nov 11, 2012 7:07 am
I'm waiting on gears and they rekon there are 10 on back order in front of me :(
Post Posted: Sun Nov 11, 2012 10:23 pm
Well i purchased the new cradle..planning on using it with justcruizin's lifted mounts. See how it all holds up!
Users browsing this forum: No registered users and 184 guests
