| GV spring the same as Vitara? http://auszookers.com/forum/viewtopic.php?f=5&t=37040 |
| Author: | BRAD [ Sun Nov 11, 2012 6:21 pm ] |
| Post subject: | GV spring the same as Vitara? |
hi there would anyone know if gv springs fit vitara because i need to buy some front 3'' cooils but the dont sell them seperatly for vitara (that ive seen) only GV and are they the same height? thanks heaps |
| Author: | DarkHorse [ Sun Nov 11, 2012 11:53 pm ] |
| Post subject: | Re: GV spring the same as Vitara? |
They are similar, but not quite identical. Rears will fit, but won't seat properly at the top until they wear in a bit. I've run Tough Dog GV rears for years. Fronts are the same (at least according to OME and Dobinsons spec sheets) even the same wire diameter and spring rates... GV ones are just taller. By way of real world comparison - I ran 20mm spacers on top of my OME 35mm fronts (so nominally 45mm over standard) to match the TD GV 35mm rears. Hardly scientific, but hopefully gives you some idea. I'm currently chasing some GV fronts from either OME or Dobinsons, which will hopefully match the rears. |
| Author: | BRAD [ Mon Nov 12, 2012 5:45 pm ] |
Cheers Darkhorse ill just have to try and chase up the fronts only but ill see what happens thanks |
| Author: | got_bar_work [ Tue Nov 13, 2012 2:57 am ] |
Gv manual v6 fronts give close to 3 in lift in a vit but bow a fair bit |
