Vehicle: 94 zook Sierra
Posted: Mon Nov 12, 2012 2:13 pm
Hay guys my 94 Sierra died the other day I was thinking of putting a vitara motor in G16b but I have been tOld so many different stories can anyone please help or confirm if I get the g16b and the conversion kit do I need to get the fuel tank also and what else I will need and is it easy enough to do.
Welcome to AZ! Have a bit of a search around here, there's heaps of info on this conversion. The carby motor is easier to fit but the EFi one is nicer to drive
As said do a search. I have the g16b in my Sierra. You can either get a American adaptor kit from lowrange offroad if you don't want to run a 2 inch body lift or just use the benT adaptor kit found in the business section. U will still need one if you go carby g16. You can send your vitara loom to killa kustom cables and for about $500 he will send it back as a plug and play loom. You can use the swb vit efi tank but you have to modify the bracketry in the sierra. I think you can also use a coily tank with a vit pump setup. Or you can just run a external efi pump. I have a surge tank and lifter pump aswell. Sierra radiator with a shroud is fine for cooling.
Users browsing this forum: No registered users and 154 guests
