It is currently Thu Oct 08, 2026 10:48 am
Post Posted: Sat Jan 03, 2009 2:33 am
Since petrol is getting quite cheap now I'm starting to think about using premium petrol again.
Can the J20A ecu advance the timing if using premium petrol, or does it have to be advanced manually?
2002 SWB GV
Lifted and Locked
Post Posted: Sat Jan 03, 2009 5:25 am
i notice a huge difference with my G13BB they are around the same era efi so there is my guessing advice.
Post Posted: Sat Jan 03, 2009 12:37 pm
Mmmmmm J20.... 8)
I don't know how the management on these things works exaclty, but unless it has a knock sensor I can't see the ECU changing the ignition timing outside the maps programmed into it's memory. My guess would be that you'd have to advance the timing manually.
Post Posted: Sat Jan 03, 2009 6:26 pm
You'll probably find the timing can't be adjusted. It will run better on premium though, and you'll get better economy too.
Users browsing this forum: No registered users and 115 guests
