| sill protector plate removal? http://auszookers.com/forum/viewtopic.php?f=5&t=37172 |
| Author: | coily96 [ Fri Nov 16, 2012 5:25 pm ] |
| Post subject: | sill protector plate removal? |
How does the plate behind the plastic trim come off? Looks to be tacked on. |
| Author: | zukmeista [ Fri Nov 16, 2012 5:29 pm ] |
| Post subject: | Re: sill protector plate removal? |
There are spot welds, best way to remove them is with a spot weld drill bit. |
| Author: | buzbox [ Fri Nov 16, 2012 5:30 pm ] |
Grinder. Drill it out and obviously you'd be left with holes. |
| Author: | zukmeista [ Fri Nov 16, 2012 5:33 pm ] |
Its a special drill bit, if you do it right there won't be any holes, would much prefer that than something that makes lots of sparks near your nice paint. |
| Author: | steve125 [ Fri Nov 16, 2012 5:35 pm ] |
you'll need a spot weld drill bit, costs about $12 from auto paint shops.
| Author: | christover1 [ Fri Nov 16, 2012 5:53 pm ] |
never even knew they existed |
| Author: | got_bar_work [ Sat Nov 17, 2012 2:52 pm ] |
That would have been better then welding up all the holes |
| Author: | KEENSY85 [ Sat Nov 17, 2012 3:47 pm ] |
I'd still grind them, or practice first u can still drill all the way through |
| Author: | Reubs [ Sun Nov 18, 2012 9:17 pm ] |
steve125 wrote: you'll need a spot weld drill bit, costs about $12 from auto paint shops. Trade tools have spot weld bits. I paid about $20-25 ea. for mine. Judging by the wear on my set, I used a 6.5mm spot weld bit to remove my coily sills. KEENSY85 wrote: I'd still grind them, or practice first u can still drill all the way through Don't do that - if you use a 6.5mm bit and are very precise I found you are left with just a tiny bit of weld that can be broken off easily. I only drilled through 1 when I tried an 8mm bit! |
| Author: | Lokidog [ Tue Nov 20, 2012 3:27 pm ] |
I ground mine, worked well, but obviously you need to used some filler to smooth off the grinder marks, even the really small ones. I would use the spot weld drill tip if I ever did it again. |
| Author: | coily96 [ Tue Nov 20, 2012 6:47 pm ] |
well thanks for the help, i think i will use the 6.5mm bit, not fussed on how it turns out as i plan to paint 100mm from the bottom up in black. |
