It is currently Sat Oct 10, 2026 3:12 pm
Post Posted: Sun Jan 04, 2009 8:33 pm
hi i have put a 1.6 carb motor into a sierra but im told i should run a 1.3 head but then if i can get someone who has done this b4 that will come to car i can pay to change wiring does anybody no of anybody in brissie area
Post Posted: Sun Jan 04, 2009 11:02 pm
If you are using the 1.3 head you won't need to do any wiring changes.
Post Posted: Tue Jan 06, 2009 2:56 am
but im not using a 1.3 head just asking should i use the 1.3 head
Post Posted: Tue Jan 06, 2009 1:01 pm
I'd use the 1.6 head. They are basically the same except the 1.6 has slightly bigger valves. The 1.3 manifold will bolt to the 1.6 head but that's not a great idea because of the smaller carb.
Have a look to see what wires are going to the 1.6 carb. There might be a couple of solenoids on the manifold too. Post up what you find and we can probably sort it out.
Post Posted: Tue Jan 06, 2009 8:12 pm
so a 1.3 intake manifold willl bolt up that would help heaps cause i have a snorkel but comes out other side the 1.6 intake crosses over to the other side of the motor or could i just put the intake stuff to the carby off a 1.3 to my 1.6 carby
Post Posted: Wed Jan 07, 2009 3:07 pm
The throat size of the carbs are different, so just swapping over the hats isn't going to work.
I removed the jack mount on the passenger side guard an mounted the stock 1.3 air box on that side. Then hooked it up to the 1.6 crossover pipe. I made a connecting pipe out of exhaust tube and bends to match them up, which you can have a look at if you want.
Post Posted: Wed Jan 07, 2009 8:29 pm
yeah man 4 sure pm me your num or sumtin that would be awsome have you got a 1.6 carb in a sierra cause i need to see one would help me out heaps
Post Posted: Wed Jan 07, 2009 8:43 pm
I had a 1.3 in a Sierra, a Megasquirted 1.3 using a 1.6 TBI manifold in a Sierra, and now i've got a 16v 1.6 with factory management in a Sierra. None of which will help you much :P
Have you looked on suzukiinfo.com? You should be able to find a manual for you Vit there, and i'm guessing that will have a wiring diagram in it.
Users browsing this forum: No registered users and 324 guests
