| 03 GV Ignition http://auszookers.com/forum/viewtopic.php?f=5&t=37242 |
| Author: | NomadGV03 [ Tue Nov 20, 2012 12:44 pm ] |
| Post subject: | 03 GV Ignition |
Does anyone know how to clean these or do they just need to be replaced? There is alot of corrosion and rust which is preventing contact points. See pics |
| Author: | shabz [ Tue Nov 20, 2012 9:37 pm ] |
| Post subject: | Re: 03 GV Ignition |
I didn't even know those things come apart! If they're giving you issues i'd say try to give the contacts a good clean and see if you can get them going again - steal wool and wd40 maybe? |
| Author: | NomadGV03 [ Tue Nov 20, 2012 10:23 pm ] |
Yeh it's just a rubber sleeve that slips onto a 10mm barb but there is a bolt on the inside that i wasn't able to remove, so i just used some wd-40 and scratched up the bolt to make better contact.. Idles beautiful now |
| Author: | fordem [ Wed Nov 21, 2012 1:30 am ] |
I use a small "cup style" wire brush in a Dremel rotary tool. |
| Author: | NomadGV03 [ Wed Nov 21, 2012 4:36 am ] |
fordem wrote: I use a small "cup style" wire brush in a Dremel rotary tool. Ah yeah i was thinking of buying a dremel 4000 as they can be so handy. |
| Author: | GeckoXL7 [ Wed Nov 21, 2012 7:30 am ] |
I always wondered how long these coil packs last, seen the price of them vary a lot, but never heard or read of one failing. But now you have made me want to check mine... |
| Author: | fordem [ Wed Nov 21, 2012 11:11 am ] |
They do fail occasionally - I haven't had any on my GV fail, but my sister has had two go on her V6 Vitara. In addition to the coils there's also an ignitor transistor inside them. |
| Author: | NomadGV03 [ Wed Nov 21, 2012 11:27 am ] |
Luckily i kept the old ones out of my other GV i had as these arn't cheap and no rust on these |
