It is currently Fri Oct 30, 2026 7:55 pm
Vehicle: 94 Vitara LWB G16b
Post Posted: Wed Nov 21, 2012 10:33 am
EDIT : Sorted. Fuel pump had died.
Hi Guys,
g16b vitara.
Filled up with fuel (Unleaded) on the way to work. Got to work fine (about 10km from petrol station). Went to start it just now and it won't start.
- Turns over, does not fire.
- checked fuses under drivers dash, and the 3 big ones in engine bay, right side. (Mind you...one of them - the biggest - I could not get out..but the fuse looks fine)
- Spark from coil to dizzy is good
- have not checked spark on each lead out of the dizzy (do I need to? Will have to orgniase someone to come help me)
- I can't hear the fuel pump making noise...but I can't say I ever have in the 6 years i've owned it.
It did have a new dizzy and fuel pump/filter about a year ago (not that it means much, as they can both die obviously)
Hopefully I can get some more ideas, but my thoughts are to check;
1) Where is the fuel pump relay and fuse?
2) What is the best way to check if fuel is getting to the engine? Can I just pull off one of the lines into/out of fuel rail? If the igntion is on (car not started obviously), should there be a constant flow of fuel? drizzle or pressure?
3) What else should I check?
Post Posted: Wed Nov 21, 2012 10:40 am
To check fuel flow, locate fuel pump relay (should be near battery somewhere) remove and crank engine to release pressure, then undo fuel line, refit pump relay and turn on igniton but don't crank, fuel should come out.
Post Posted: Wed Nov 21, 2012 10:42 am
Ok thanks.
Does anyone have more info on how to tell which is the Fuel Relay?
Post Posted: Wed Nov 21, 2012 10:48 am
Just did a bit of googling, it appears it is green, under the dash by the ECU.
Post Posted: Wed Nov 21, 2012 7:15 pm
thanks. No pressure on rail....relay ok...getting voltage on both sides of rely....looks like it's the pump. I am going to get it towed tomorrow :(
Post Posted: Mon Dec 03, 2012 12:32 pm
it was the fuel pump. Ebay pump was worth a go, but didnt have the luck others did on here.
Post Posted: Mon Dec 03, 2012 10:14 pm
Have you checked the wiring? its not uncommon for it to be corroded behind the rear light cluster.
Post Posted: Tue Dec 04, 2012 11:49 am
Thanks Rhinoman. It was the fuel pump.
for future searches - the wiring connector for my pump was dead centre in the rear bar, There was also connectors at the tail lights however.
Users browsing this forum: No registered users and 350 guests
