It is currently Fri Oct 02, 2026 8:10 pm
Post Posted: Thu Nov 22, 2012 8:53 pm
hi all, i have been told since the 1.3l engines are old, it doesnt hurt to run some thicker oil through them every now and then. and i have heard that you can run diesel oil in them? but im not to sure and was just wanting your oppions on doing so and also if you can run diesel oil in them what do use guys recommend using? cheers.
Post Posted: Thu Nov 22, 2012 8:58 pm
You don't run diesel oil because its thicker...... Its not. Well.. it; like petrol oils; is available in different viscosities.
You run diesel oil because it has more detergents in it. This will remove carbon build ups ( slowly ).
The downside is, that if your motor is old and grubby on the inside, the carbon deposits may actually be stopping it from leaking. The diesel oil MAY cause oil leaks after some time, as it will remove the coking and carbon build up from the motor.
Having said that, I only run diesel grade oils in my suzuki's.
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Thu Nov 22, 2012 9:33 pm
castrol J Max or castrol Tection HD. thats what i run in mine
Vehicle: LJ50V, SJ70
Post Posted: Thu Nov 22, 2012 10:01 pm
"Diesel" engine oil is not exclusively for diesel engines. There are two important specs you should check when picking an engine oil. Viscosity is an important one, as too thin can cause engine wear while too thick can cause drag and loss of power. Go with an oil close to what's recommended in the FSM or Owner's manual.
The other important spec is Grade. Diesel grade are classified like CF, CG, CH etc, while Petrol grades are SG, SH, SL, etc. To remember which is which, "C" stands for Compression Ignition, "S" stands for Spark Ignition, and as the letters go up alphabetically, the later the specification.
Typical Diesel oils such as Shell Rimula X are the right viscosity, but are only graded CH-4 and does not have a petrol grading. It should NOT be used in a petrol engine. Other types of diesel oils, such as Penrite HPR Diesel 5 or 15 are rated CI-1 AND SL. They can be used in a Petrol engine. Ensure any Diesel oil you're looking at has an "S.." grading.
Post Posted: Thu Nov 22, 2012 10:11 pm
Rob, what grade are these oils? Castrol's website isn't too clear, but it looks like these oils are exclusively Diesel oils with no Petrol grading.
Castrol Tection J Max
Castrol Tection HD
Post Posted: Fri Nov 23, 2012 7:49 am
already then thans guys, fatzook what would you recommend for m to put into my zook? cheers. and also my brother uses castrol rx super diesel engine in his nissan patrol was just wondering if that is a decent diesel oil to use? cheers for all the information
Post Posted: Fri Nov 23, 2012 8:48 am
I use 15w/40 on mine. But like 303 said, make sure it has an 'S' grading.
Post Posted: Fri Nov 23, 2012 9:11 am
ill just go with wht your using fatzook, what brand is it? cheers
Post Posted: Sat Nov 24, 2012 12:20 am
Read the second page of the Castrol spec sheet:
Castrol RX Super
Post Posted: Sat Nov 24, 2012 7:09 am
I think this warrants being placed in the Tech sub forum
Post Posted: Sun Nov 25, 2012 4:15 pm
Castrol Tection HD
for tection HD it is ok for use in petrol engine API 'SL'
But it says J Max is not suitable for petrol engines.
Users browsing this forum: No registered users and 173 guests
