It is currently Wed Oct 28, 2026 1:45 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
Vehicle: ARB Bar, 2" lift
Post Posted: Thu Nov 29, 2012 8:30 am
Hi guys
New to the forum and did a quick search which brought up all kinds of answers. I am currently running 235/75 MAXXIS Bighorns on black sunnies with an ARB bar and 2" OME lift.
My question is has anyone actually got any proof of a 2" system assisting in low down torque or even a torque increase at all through the rev range? Not interested in extra power or having it louder.
If you could point me in the right direction to some links to further my research or let me know about your own experience with this (ie components used, gains in performance and cost) it would be much appreciated.
Cheers guys
Darcy
Post Posted: Thu Nov 29, 2012 8:51 am
Darcy, On such a small motor, the difference will be almost immeasurable. Seat of the pants gains only. I'd guess that at best.....3-5% gain could be had.
Post Posted: Thu Nov 29, 2012 9:09 am
That's what I was thinking, I have people tell me all different stories about this topic. Just looking for more opinions that's all. It's a much cheaper alternative to re gearing for the bigger tyres. In the end the fuel economy isn't in any of my concerns, just a bit more torque to pull up the rough climbs mainly.
Vehicle: Suzuki Jimny 2010
Post Posted: Thu Nov 29, 2012 9:12 am
Reduction gears would far outweigh the exhaust upgrade!
Post Posted: Thu Nov 29, 2012 9:47 am
This has come up before. The only solid dump data I've seen for a Jimny showed s reduction in power after exhaust mods. As power is torque x rpm, it would be safe to assume torque dropped too.
Engine mods are no substitute for gears.
Steve
Post Posted: Thu Nov 29, 2012 10:04 am
A block swap will give you a better gain in torque etc if she is still lacking after better gearing
Post Posted: Thu Nov 29, 2012 10:36 am
Ok well what reduction gears are reccomended? What reduction percentages are offered and what work is involved?
Post Posted: Thu Nov 29, 2012 3:37 pm
did you search? Zukenutter has a good gearing thread. We don't know what model jim you have..
Post Posted: Thu Nov 29, 2012 4:24 pm
She's a 2011
Have looked into the trail jimny 24% reduction gears but with the 235s I am unsure what effect it will have on high range.
Post Posted: Thu Nov 29, 2012 7:43 pm
With 235's, In Low it will be great off road. 24% takes the gearing to the other side of stock. At highway speeds, you'll be revving at around 4,000. Bearable for short drives but could get annoying on long hauls.
Post Posted: Thu Nov 29, 2012 8:13 pm
20% would be a better option IMO for 235's
I may have some up for grabs soon... Ill keep you posted.
Post Posted: Thu Nov 29, 2012 8:30 pm
There's not really any easy options for gearing a Vvt Jimny if you want to retain highway performance and stick with 235s.
Jimny_timmys 20% reduction and a set of 31s would work well. If you're more interested in off road performance the 20% reduction with 235s would be pretty good. You could swap to earlier model diffs combined with 20% gears for a better highway outcome.
Vehicle: 2011 Jimny
Post Posted: Thu Nov 29, 2012 8:49 pm
i have 24% gearing with 30's and sits on 4400rpm at 110km's so i reckon 20% would be too much still for 235's.
Vehicle: SV420
Post Posted: Thu Nov 29, 2012 9:45 pm
A nice exhaust adds alot to the drivers experience in my opioin
Post Posted: Thu Nov 29, 2012 10:46 pm
Cheers mate much appreciated
Post Posted: Thu Nov 29, 2012 10:48 pm
Personal experience? If so what mods did you make?
Post Posted: Fri Nov 30, 2012 5:20 am
There's an interesting thing... I ordered 20% reduction and get the same on 30's at 110km/h
Either way, like Zukenutter said, my gears would be great for 31's and highway driving, but the low is just a little too high for my liking on 30's and IMO would be perfect for 235's. but highway will suffer.
Post Posted: Fri Nov 30, 2012 6:10 am
If money is not a problem, at around $2k for the gearset, APIO has a 58% low only reduction. You can also combine these with a trialjimny hi/lo kit.
Post Posted: Fri Nov 30, 2012 7:57 am
Can you provide a link to a site that resells them? I can't seem to find one. Have heard good things about them, cause honestly low only would be excellent.
Vehicle: 92 lwb vitara
Post Posted: Fri Nov 30, 2012 3:19 pm
on the other end the scale , i beleive a snorkel makes a big improvement - the induction noise is very lound when your on the pedal-(jim seems to be more esponsive )
i havent done the exhaust yet - but fine it hard to beleive a set of headers and pipes would not improve torque ???
i will be doing a exhaust system soon - but will not be dynoing car
Post Posted: Fri Nov 30, 2012 3:50 pm
Like Steve has said, there are dyno readouts as proof for a jimny showing that there was a decrease in torque and hp. That being said, I can't recall if it was a complete system overhaul?
On the other hand, my exhaust, headers and snorkel combined gave me about a .5-.8l/100km difference in fuel consumption.
Post Posted: Fri Nov 30, 2012 4:04 pm
damn straight... i miss the tune that my J20a would sing. Armsup
Post Posted: Fri Nov 30, 2012 4:17 pm
Jimny Dyno results, before and after header and exhaust upgrade. Torque is up, HP is down and quite flat. Also looks like it didn't want to reach the same top speed.
BEFORE
http://www.jimny-crew.com/jimny-on-the-dyno.html
AFTER
http://www.jimny-crew.com/exhaust-upgrade-dyno-results.html
Post Posted: Fri Nov 30, 2012 4:22 pm
I love that mine doesn't drone on the highway like the Black Jim did. I just wind the window down and listen to the induction note through the snorkel instead, cooler sound anyway ;)
Post Posted: Fri Nov 30, 2012 5:43 pm
Indeed, an exhaust note can make a car a lot more enjoyable. Unfortunately though, it might not add any actual performance.
If you made a modification to your car and it made absolutely no difference to it's sound, you'd be AMAZED at how much power you'd have to add before you felt the increase.
Nobody has EVER claimed extractors made their cars go slower, but the dyno doesn't lie. In some cases, they may well, but because the car sounds faster, your "ear of the pants" is convinced it is.
Post Posted: Fri Nov 30, 2012 6:20 pm
Plus you have a few hundred reasons to believe it is performing better afterwards.
Vehicle: 2012 jimny
Post Posted: Fri Nov 30, 2012 9:39 pm
I would imagine the drop in performance by simply adding an exhaust system and nothing else could possibly be attributed to not setting up the whole system and tuning to suit? I would have thought a well sized(read not to big or small) exhaust with free flowing catalytic converter and muffler combined with some better intake flow and an interceptor style chip tuned to suit would make a small but noticeable increase in performance. considering 400-600 for the exhaust if you get it cheap, 900 for the chip and couple hundred for a tune plus what ever the intake costs its not a cheap exercise for a small increase. Having said that if i could measurably increase performance a bit id probably give it a go but im a sucker for after market stuff like that hahaha
Post Posted: Sat Dec 01, 2012 5:25 am
So gears are not sounding that expensive in the end
Post Posted: Sat Dec 01, 2012 7:35 pm
BEFORE
AFTER
i read this post - WHEN LOOKING FOR EXTRACTORS FOR MY 2005 MODEL" NO ONE MAKES EM"-
well my question is who the hell made these non preformers?- no infromation given on manifold configuration- primary tube o.d and lenghth , pictures etc
it sounds like a back yarder job to me - id take this post with a grain of salt
thats just my 2 bob
Post Posted: Sun Dec 02, 2012 8:10 am
Why would someone go to the trouble of driving an hour to Dyno (twice) and then do a backyarder job. Doesn't add up.
Doesn't look backyard to me
I agree that more info would have been good but this Jimny was written off at some point so I dare say that was the end of the testing/reporting.
Users browsing this forum: Google [Bot] and 369 guests
