It is currently Tue Nov 03, 2026 5:41 pm
Post Posted: Wed Dec 05, 2012 6:45 pm
Lost or couldn't find original thread.
Due to recent enquiries,
popped this up in case it helps.
I believe its worth the upgrade, if you have a LWB.
I got all the bits from a bloke doing a conversion into his 1.3.
With a SWB probably cheaper to buy a good 1.3 to start with.
Not a simple bolt in, but easy enough if you have all the bits.
I had a 1.3 in my 1.0 LWB.
I used entire 1.3 motor gearbox and jack shaft.
Unis can be half 1.3 and half 1.0 yokes.
Engine mounts and gear box mounts need fabbing.
Small wiring changes to suit 1.3 alternator.
OLD OL thread http://www.outerlimits4x4.com/viewtopic ... conversion
OLD MAG ARTICLE here https://skydrive.live.com/?cid=702b0da9 ... 451F%21978
I used to have a topic on it on AZ.
Will try to find it buts heres pix.
Vehicle: '84 LWB 1LTR
Post Posted: Thu Dec 06, 2012 9:42 pm
Well done mate :)) 1.3 appears to be lower then standard???
Post Posted: Fri Dec 07, 2012 5:24 am
Was actually about 5mm higher, but body lift could make engine appear lower than stock.
Post Posted: Sat Dec 08, 2012 9:58 am
have you got any more pics of the engine mounts? might fab some up for my ute
Post Posted: Sat Dec 08, 2012 10:03 am
Post Posted: Sat Dec 08, 2012 12:31 pm
any chance of you making some more? :P how did they handle the abuse?
Post Posted: Sat Dec 08, 2012 12:44 pm
They never had any problemsw in my years of use.
Guy who bought them had no probs either.
They are just flat 8mm plate, drilled to suit.
Bracing isn't necessary.
Welded nuts helps, but ain't needed.
Had to trim a little to miss the extractors.
No way I could make them without a Sierra.(I a softy girly vit owner now)
I just slotted the motor in, stuck plates in, and marked the holes out.
Post Posted: Sat Dec 08, 2012 12:48 pm
ill have to take the cab off and dodge it all up. if only there was an off the shelf option lol
Users browsing this forum: No registered users and 372 guests
