It is currently Sat Oct 31, 2026 12:21 am
Vehicle: 1994 WT Sierra
Post Posted: Thu Dec 13, 2012 11:31 am
Hi guys,
Just this week I noticed a noise that has always been in the car suddenly become louder. Took it to my mechanic who road tested it. He said it sounds like a bearing or possibly a broken gear in the gearbox. This would make sense to some extent - the noise was always there, and now after replacing the really thick, really black gear oil with fresh stuff, it is suddenly louder.
But, does this mean my gearbox is about to go? Mechanic seems to think it'd be pretty risky attempting to drive to QLD and back on it...
So, does anyone know a manual gearbox specialist in Sydney that could help diagnose it?
Does anyone have a gearbox that's in good nick that they'd be willing to part with?
Are Swift/Vitara boxes compatible?
Cheers,
KD.
Post Posted: Thu Dec 13, 2012 11:33 am
Swift gearbox is definitely out, FWD! Vitara won't fit without mods.
Post Posted: Thu Dec 13, 2012 12:14 pm
Check the rear wheel bearings. When they are stuffed it can sound like a gearbox issue?
Post Posted: Thu Dec 13, 2012 12:19 pm
Good thought Shep. Unfortunately I don't think it could be that simple though - just did the wheel bearings about 3 weeks ago.
Post Posted: Thu Dec 13, 2012 4:25 pm
I bet you are now wishing that you did more regular planned maintenance to your vehicle.
Neither Swift nor Vitara gearboxes are any good as Sierra replacement.
Post Posted: Fri Dec 14, 2012 2:32 pm
Took the Sierra to a Gearbox/Diff specialist this arvo. Within about 10 seconds of driving he said "It's not your gearbox. It's your transfer case."
So - does anyone near Sydney have a transfer case they'd be willing to part with? Or know where I could get one?
Cheers,
KD.
Post Posted: Fri Dec 14, 2012 4:46 pm
Before spashing cash,
consider borrowing a good xfer and test that.
They are quite easy to remove and install.
Post Posted: Wed Dec 19, 2012 6:58 pm
Ok I've managed to find a NT transfer. I've been told the flanges are different, which is ok, as I can swap the flanges over from my buggered WT transfer. But are the ratios the same or are they different?
Cheers,
KD.
Post Posted: Wed Dec 19, 2012 9:23 pm
Same.
Only 1L and coily transfers are different to 1.3 leafy cases.
Users browsing this forum: Google [Bot] and 346 guests
