| Author |
Message |
logan
Vehicle: suzuki sierra
 Posted: Sun Dec 16, 2012 10:48 pm |
Has anyone had bad experience with checker plate ? If do any other alternatives ? Cheers
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Sun Dec 16, 2012 11:00 pm |
They are a bit cheezy, and the bars can be uncomfortable against your leg/ knee.
Otherwise they are ok I guess.
_________________ 2013 GV 1998 SV420 ute
bogga
Joined: Sun Sep 20, 2009 11:30 pm Posts: 704 Location: Coffs Harbour
 Posted: Mon Dec 17, 2012 9:16 am |
Bugger that.... had em but kept smashing my knee on it till it bled when out wheeling.
So made up some cards with ply and marine carpet......easy as and cheap.
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9715 Location: NSW
 Posted: Mon Dec 17, 2012 11:36 am |
Carpet
Coilydoors trims
abs lowrange ones
remake your ones and coat in viylne
pezz
Joined: Fri May 15, 2009 11:30 pm Posts: 2108 Location: western vic
Vehicle: sj51
 Posted: Mon Dec 17, 2012 12:23 pm |
Mine came with brand new checkerplate trims, im looking to offload then... checker plate is for standing on only in my opinion.
masterA
Joined: Tue Jan 18, 2011 3:24 am Posts: 976 Location: Perth
 Posted: Mon Dec 17, 2012 12:41 pm |
I'll second the bleeding of the knee and they also get hot so when you got a wound and a hot plate it's not much fun Get some coily door trims
suzukiboy
Joined: Sat Jul 22, 2006 11:30 pm Posts: 607 Location: Brisbane
Vehicle: Suzuki Grand Vitara
 Posted: Mon Dec 17, 2012 1:41 pm |
I will be making door trims next year, I can make them out of plastic, board, aluminium, cardboard.
Will be making mine out of a brushed aluminium 3mm sheet (dibond) with SUZUKI or SIERRA engraved in them.
I can buy the sheets in different colours, finishes and can also print a picture/logo on them them.
logan
 Posted: Mon Dec 17, 2012 10:47 pm |
Aha okay so that's a definite no to checker plate! Ahah I still have the old door trims, could you just take off the old plastic and put some carpet around the frame? Or would you have to make another door trim and start from there?
foolsp33d
Joined: Tue Mar 11, 2008 10:30 pm Posts: 2123 Location: Deep Inside Jamies Mouth
Vehicle: Clown Car..
 Posted: Mon Dec 17, 2012 10:58 pm |
go purchase some ply with the $$ you would spend on the shitter plate. trace and cut out the old door trim, a can of spray adhesive, some hot glue, bit of marine carpet or vinyl . Bang.. new door trims.. with no knee scaring. http://www2.izook.com/?page_id=222
