| Hub leaking grease http://auszookers.com/forum/viewtopic.php?f=5&t=37827 |
| Author: | Scales [ Wed Dec 19, 2012 9:16 am ] |
| Post subject: | Hub leaking grease |
Hey all. Just noticed this when I was cleaning the car. Cause for concern? Or have I just stuck too much grease in there at one stage? I have degreased it off now.
| Author: | tanshi [ Wed Dec 19, 2012 9:21 am ] |
| Post subject: | Re: Hub leaking grease |
leaking axle seal i would say. it will keep leaking and eventually you will need to fix it up, but it happens to us all |
| Author: | Scales [ Wed Dec 19, 2012 9:33 am ] |
Oh righto. I only just changed them a year ago. I thought it was grease, was pretty thick |
| Author: | tanshi [ Wed Dec 19, 2012 9:36 am ] |
its washing the grease out of your CVs |
| Author: | brindog [ Thu Dec 20, 2012 5:12 am ] |
Rookie question but, Could water in the diff/axel cause this as well? |
| Author: | tanshi [ Thu Dec 20, 2012 5:14 am ] |
i suppose water would cause the seal to tear up thus causing this. |
| Author: | 303zuke [ Thu Dec 20, 2012 7:37 am ] |
Scales wrote: I only just changed them a year ago. No-Name Brand? You get what you pay for. Saving $2 on a seal means you get to rebuild your front end each year. |
| Author: | dirtydogz [ Thu Dec 20, 2012 8:02 am ] |
You only need to fill the cv knuckle with about 100ml of grease that's all suzuki recommend. |
| Author: | Scales [ Thu Dec 20, 2012 8:16 am ] |
Reputable brand seal. Oh well, I'll have to do it again I guess. No big deal. Any suggestions where to buy these? I think I went o/s last time. |
| Author: | tanshi [ Thu Dec 20, 2012 8:27 am ] |
if your just doing the seals buy them from a bearing shop. should be no more than $5 each |
| Author: | Scales [ Thu Dec 20, 2012 10:55 am ] |
Ah right so just take the old ones in then? Or do I need to get axle dimensions? I have been a bit of a mail order whore lately.... |
