It is currently Tue Sep 22, 2026 7:20 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
Vehicle: 2000 model Suzuki Jimny
Post Posted: Thu Dec 20, 2012 4:32 pm
Okay,
Gearing for a manual 2000 model non VVT Suzuki Jimny.
I am lead to believe that a non-VVT Suzuki jimny has a Final Drive Ratio (Diffs) of 3.416 and
a Suzuki jimny with VVt has a ratio of 4.3
Does this mean that if i put the Diff centers from a VVT jimny into my Non-VVT i would get a gear reduction of the above figures.
Also, would someone be able to work out this reduction as a percentage please.
I am just looking into other ways of reducing the gears on my Jimny other than through the transfer case swap.
Thanks,
Joel
Post Posted: Thu Dec 20, 2012 5:18 pm
You've been lead down the garden path.
4.1 and 4.3 are the only factory ratios available for the jimny AFAIK.
Not sure which models they come in though.
EDIT: 4.7% difference.
Post Posted: Thu Dec 20, 2012 6:02 pm
Hey,
Just doing some reading,
Because from what i have read the automatic jimny's transfer has a
high ratio of= 1.32:1
Low ratio of = 2.643:1
Compared to the manual-
High= 1:1
Low= 2:1
would it be possible to put the automatic transfer case into a manual and get whatever this reduction works out to be?
And If before 2006 was 4.09 diff ratio i could put in the diffs of a 2006 + VVT = 4.3
which would lower the gearing again.
Thanks,
Joel
Post Posted: Thu Dec 20, 2012 6:37 pm
As far as im aware the auto into manual transfer swap has been done before and was about 13% reduction if i remember correctly.
Fatzook posted the diff ratio percentage as 4.7% above.
Post Posted: Thu Dec 20, 2012 7:16 pm
So if i put in the 4.3 diff's and an auto transfer box i would have roughly a 4.7% reduction when driving at all times and then a 13% reduction + 4.7% in Low 4wd.
I that correct?
Post Posted: Thu Dec 20, 2012 7:22 pm
I'm not the best with knowing what works in what , but given the post above says the auto transfer is 1.32:1 and manual is 1:1 I would think that was a 32% diference . I could be very wrong , but it's worth a second thought.
Post Posted: Thu Dec 20, 2012 7:32 pm
Yep, that's the way I figure it.
Non Vvt Jimny manual transmission transfer is 1.3:1. Vvt manual transmission transfer (push button) is 1:1
Vehicle: 95 sj70 and 78 lj81
Post Posted: Thu Dec 20, 2012 7:35 pm
http://www.lepayne.com/gears.html
As the saying goes teach a man to fish bla bla bla
check this link you can do it all yourself. There is others out there as well
Post Posted: Thu Dec 20, 2012 7:53 pm
So non- Vvt manual has a high of 1.3:1 and a low of 2:1
So in high there is very little difference,
But in low it is considerable reduced.
With a low ratio of 2.643:1, what size tires would it be possible to run comftorbaly?
Post Posted: Thu Dec 20, 2012 8:02 pm
Someone's been giving some rather conflicting info.
Check this for more accurate info. 2.643 low is only in Vvt transfer.
http://www.bigjimny.com/images/documents/transferboxratios.pdf
What size tyres are you hoping to run?
Post Posted: Thu Dec 20, 2012 8:08 pm
So is the Vvt transfer all electric, no stick. So it would not be possible to fit it into a non-Vvt jimny.
I was looking to run around 30's but was looking for a different way to do it other than transfer swap to a Sierra box.
Post Posted: Thu Dec 20, 2012 8:48 pm
Yep Vvt is all electric and a lot of trouble. You could swap to a Vvt gearbox for about 25% reduction but your highway speed will be affected. 31s would work reasonably well but still low'ish on the highway.
Sierra case with 4.16 gears would be a better way to go but there are hassles from old hardware.
Post Posted: Thu Dec 20, 2012 8:49 pm
Is your Jimny M motor or G motor?
Post Posted: Fri Dec 21, 2012 5:47 am
it is a 2000 model jimny, manual, with the G13bb engine.
So if i swapped to a Vvt-gearbox i would get a 25% reduction overall, or just in high range.
Thanks for all your help so far,
Joel
Post Posted: Fri Dec 21, 2012 8:39 pm
Ah G motor. I don't know whether the Vvt box will mate with it.
Post Posted: Fri Dec 21, 2012 8:40 pm
Oh yeah 25% high and low.
Post Posted: Sat Dec 22, 2012 6:17 am
So i need to get hold of a Vvt-gearbox and see how different it is from one for a G series. So if it works it will give a 25% reduction in high and low.
That's good!
Stupid question, if the Vvt model has this box, a slightly more powerful engine, how will this reduce it by 25% going into a G series Jimny?
Thanks,
Joel
Post Posted: Sat Dec 22, 2012 7:36 am
VVT gearbox is geared lower then that model is geared back up at the transfer case. Transfer high range is 1:1
I haven't had a G Jimny but judging from the Big Jimny ratio guide it should work.
Post Posted: Sat Dec 22, 2012 3:20 pm
So i need to get hold of a Vvt gearbox, is basically what it comes down to.
If i can get it too fit i will get about 25% reduction
Which will be good for 31's?
Is there different model Vvt gearboxes (aka which year models should i be looking at?)
Thanks heaps zukenutter,
Very knowledgeable in this section
Joel
Post Posted: Sat Dec 22, 2012 6:44 pm
Like I said I don't really know anything for sure about G motored Jimnys.
If the transfer ratio and diff ratios were the same as my Non Vvt motored Jimny was, and if the gearbox bolts to the engine which I don't think they will it should work with 31s. Also the rear gearbox mount will probably need modification. It may end up a bit lower than a standard Jimny, 5% give or take.
Mubby bought my old 2006 Vvt gearbox for his 2010 so I imagine all vvts are same or very similar. He didn't mention noticing any ratio difference.
All I know is what I've discovered through trial and error. Certainly not knowledgable like a lot of people here though.
Are you planning
Post Posted: Sat Dec 22, 2012 7:08 pm
Do G13BB transfers swap to M13 gearboxes? Vice Versa? They are a different gearbox AFAIK.
Post Posted: Sat Dec 22, 2012 10:19 pm
Fatzook, I don't know if the transfers are the same, but I reckon there's a good chance they're the same, bigjimny guide shows same ratios and I don't think the G would use a coily transfer. Jimny has gearbox and transfer linked by an intermediate shaft so may need a modded Vvt shaft. Pretty sure the flanges will be the same. Shame I don't have my old gearbox I could've made a bell template and found a g motor to test it against.
The Vvt gearbox main output is a slightly different size spline to the non Vvt M.
Juniorjoel you'll be entering unknown territory with this swap.
Also you'd need to use a Vvt intermediate shaft which may need to be modified.
Post Posted: Sat Dec 22, 2012 10:30 pm
Hasn't Zukenutter done all this before?
Post Posted: Sun Dec 23, 2012 7:10 am
Yes I have but in reverse and not involving anything which came from the factory with a G13BB.
Is my avatar confusing ? :D
Post Posted: Sun Dec 23, 2012 7:22 am
Thanks Guys,
I will probably do what you were thinking and make up a template to see if the bell-housing will bolt up.
Yeah, i have seen that the rear end of the Vvt gearbox is different, but if i make a template and it works out that it would bolt up then i will give it a try.
Thanks again,
Joel
Post Posted: Sun Dec 23, 2012 9:53 pm
Yes. Didn't even notice it was you :lol:
Post Posted: Mon Dec 24, 2012 8:16 am
Just for accuracy, although the specs say that a VVT auto Jimny T-case is 1.32 and 2.64, I have counted the teeth and the ratios are actually 1.27:1 and 2.54.
Post Posted: Mon Dec 24, 2012 9:51 am
The "m" series box won't bolt upto the g series motor. Just do the Seirra t-case swap and call it good. It would be ALOT less hassle than a gear box swap, less time in doing the coversion and you will be a lot happier with your gearing compared to the gear box swap (that won't work). Plus you are removing the chain drive transfer which tend to slip as they get older. JMO
Post Posted: Mon Dec 24, 2012 10:58 am
I had an auto VVT box in and it slipped after 1 day at glasshouse. I pulled it and my manual box apart and discovered that the manual box chain is 5mm wider (and a few links shorter) which would make it stronger.
Post Posted: Mon Dec 24, 2012 11:40 am
Okay then,
Well if the box doesn't fit i guess i will just have to source the parts and do a sierra transfer swap.
Thanks for all the help guys.
Joel
Users browsing this forum: Google [Bot] and 199 guests
