Joined: Fri Oct 30, 2009 10:30 pm Posts: 1754 Location: North Brisbane
Posted: Mon Dec 24, 2012 7:28 pm
Just putting a basic Pioneer stereo into the Jimny and my usual trick of using ground down crimp pins into the factory plug isn't working too well. Can't get them to the correct shape to make good contact. Outer pins are ok, its the speaker connections in the middle section. So... Is this plug the same as any other brand? Do the late and early Jimnys use the same audio plug or did they change between the different series - Mk I/II/III? Is there some better crimp terminals available that will do this job?
Went to Autobarn. I can't justify $30 times 2 for adapter cables. (Suzuki to ISO, ISO to Pioneer)
Users browsing this forum: Google [Bot], shakes and 161 guests
