It is currently Tue Oct 20, 2026 1:23 am
Vehicle: 91 Vitara G16b AT
Post Posted: Thu Dec 27, 2012 6:41 pm
Hi Guys, thanks for your help.
I have an ongoing problem, leaking oil on my Vitara. The Valve cover bolts always loosen. Some to the point that they are just sitting in the bolt hole.
I haven't overtightened them since i had the vehicle, but i am assuming someone previously has.
Should i just use a small amount of loctite? Or does anyone have a better solution?
Thanks a lot;
Post Posted: Thu Dec 27, 2012 6:47 pm
something like a light/medium strength loctite would be fine, the blue stuff should do it.
Post Posted: Thu Dec 27, 2012 6:55 pm
Thanks a lot, didn't know they had different grades of the stuff, i will grab a light grade like you recommend and give it a go tomorrow.
Thanks for your help
Post Posted: Thu Dec 27, 2012 6:57 pm
the gasket might be shrinking - collapsing so they have no tension on them and start to unwind
If it leaks replace it anyway and see how you go, I seem to have to replace mine every 40000km
Post Posted: Thu Dec 27, 2012 7:08 pm
This has happened since Feb when i bought the car; i replaced the gasket then due to oil leaks for RWC but within the week they were loose and unwinding. The gasket still seems to be good, i have cleaned it all up, and will re seal it tomorrow, and hope for the best.
Post Posted: Fri Dec 28, 2012 2:36 pm
my vit's rocker cover gasket used to leak too, replace the gasket, still leaked, swapped the gasket for Goo, No more leaks 30xxx km's later :)
Users browsing this forum: Google [Bot] and 414 guests
