http://auszookers.com/forum/
Jimny adjustable panhard rods
http://auszookers.com/forum/viewtopic.php?f=5&t=37966
Author:  Gough [ Fri Dec 28, 2012 10:05 pm ]
Post subject:  Jimny adjustable panhard rods
Does anyone one havr a how to of installing adjustables panhard rods into a jimny after a 50mm lift ?
Author:  jimny_timmy [ Sat Dec 29, 2012 10:54 am ]
Post subject:  Re: Jimny adjustable panhard rods
Wind the threads on each end to as close to halfway as you can get, install it and then measure from certain point on each side to get it centred. Using a large spirit level and resting it against your guard (pending its still straight) and measuring to your tire will work, or vice versa if your tires hang out past the guards :)
Author:  Scales [ Sat Dec 29, 2012 11:28 pm ]
when you get your wheel alignment done (which i hope you are going to do now your geometry has changed), get the tyre bitches to do it. back end you can do with a mk 1 eyeball.
