It is currently Wed Oct 21, 2026 7:59 pm
Vehicle: 99 JLX Suzuki Jimny
Post Posted: Fri Dec 28, 2012 10:05 pm
Does anyone one havr a how to of installing adjustables panhard rods into a jimny after a 50mm lift ?
Vehicle: Suzuki Jimny 2010
Post Posted: Sat Dec 29, 2012 10:54 am
Wind the threads on each end to as close to halfway as you can get, install it and then measure from certain point on each side to get it centred. Using a large spirit level and resting it against your guard (pending its still straight) and measuring to your tire will work, or vice versa if your tires hang out past the guards :)
Post Posted: Sat Dec 29, 2012 11:28 pm
when you get your wheel alignment done (which i hope you are going to do now your geometry has changed), get the tyre bitches to do it. back end you can do with a mk 1 eyeball.
MY BUILD THREAD HERE!!!!!
Users browsing this forum: Google [Bot] and 112 guests
