It is currently Sun Oct 25, 2026 2:29 am
Post Posted: Mon Dec 31, 2012 4:05 pm
hey all,
just pulled out my out transfer case and seen that the new case has a different colour/size speedo gear. This means that my old speedo drive on the chassis side wont drive the gear inside the case.
Can i fit another gear from a different yr or do i have to crack open the new case to swap gears? i dont know what year the new case come from, but the gear inside is blue and mine is a yellow/white. The yellow gear is maybe 2mm away from the gear inside the new case.
If i do have to open it all up, please explain????
cheerrss
Post Posted: Mon Dec 31, 2012 5:27 pm
i'm just replying here to get your hopes up that i have some useful info to contribute, other than being the one to notice that your speedo gears werent meshing in the first place, and saving you from dropping a tcase on your face TWICE =) lol
PS: got to nearly 42*C outside while we were in your garage, no wonder i thought it was hotter while i was in the car. lol
Post Posted: Mon Dec 31, 2012 5:47 pm
YOU suck, checked my emails to see a reply and its you! thanks
well that new cross-member bolted up really nicely :D i now have nothing below my chassis besides the obvious (diffs and front cross-member)
Post Posted: Mon Dec 31, 2012 6:02 pm
nice - was the transfer mount that was all twisted up by the old crossmember still ok?
have you re-filled the new case and gearbox via the shifter holes? =)
Post Posted: Tue Jan 01, 2013 12:59 am
Munted fill/drain plugs?
You dropped it on your face? :rofl: I said in your lap, Mitch!
Did you find the pic of the two speedo senders?
I'm sending you this:
I've sent you a PM too - might have a buyer for the motor, so the gearbox might be available.
Post Posted: Tue Jan 01, 2013 3:00 am
yeah Rob, i found the pic after i called you. Yes that is what i need :D
yeah that mount was fine, better than the "torque stopper bush" mount anyway.
tried to fill the gearbox up that way but i think you must have to do it before fitting the shifter linkage housing, as it just kind of filled up and over flowed ahaha.
ill fill with oil in the morning and go for a drive. Wanna have a low range drag race??
Post Posted: Tue Jan 01, 2013 11:39 am
hell yeah i do! =)
Post Posted: Tue Jan 01, 2013 12:14 pm
alien wrote:
hell yeah i do! =)
im planning on going for a swim then to cinta's, ill give you a buzz when im free.
Users browsing this forum: Google [Bot] and 137 guests
