| 1986 sj50 sierra cat converter http://auszookers.com/forum/viewtopic.php?f=5&t=38032 |
| Author: | harry loane [ Tue Jan 01, 2013 2:28 pm ] |
| Post subject: | 1986 sj50 sierra cat converter |
hey guys just need some help. I got a new 2.5 inch exhaust system and extractors from a friend and i was just wondering if you need to run a cat on it being a 86 model. thanks harry |
| Author: | cairns27 [ Tue Jan 01, 2013 4:18 pm ] |
| Post subject: | Re: 1986 sj50 sierra cat converter |
My '87 has been through two RWC without one, but a fitter told me it's quite a big fine if caught in roadside check. bye |
| Author: | harry loane [ Tue Jan 01, 2013 4:22 pm ] |
Ok so would it be worth putting one on incase |
| Author: | want33s [ Tue Jan 01, 2013 8:21 pm ] |
Technically an 86 model petrol 4wd isn't required to run a cat conv. but seeing as everyone now uses unleaded fuel I think every petrol vehicle should have a cat fitted. |
| Author: | harry loane [ Wed Jan 02, 2013 8:20 am ] |
Ok so I don't NEED one I should just have one on. The system has a cat but its straight off the back of the Extractors and the cat hits the chassis rail So that's why I wanted to know if I had to have one |
| Author: | McBane [ Fri Jan 04, 2013 9:02 pm ] |
if it runs as bad as most carby g13's a cat would be stuffed in about 10mins flat un burnt fuel will kill their coating |
| Author: | harry loane [ Fri Jan 04, 2013 11:29 pm ] |
Myn is a g13b and it runs pretty good with the 2.5 inch system |
| Author: | matty_wall [ Sat Jan 05, 2013 5:51 am ] |
so you're running a GTI motor? If you are you need to legally run a cat. |
