It is currently Thu Nov 05, 2026 5:35 pm
Vehicle: 1986 sj50 suzuki sierra
Post Posted: Tue Jan 01, 2013 2:28 pm
hey guys just need some help. I got a new 2.5 inch exhaust system and extractors from a friend and i was just wondering if you need to run a cat on it being a 86 model.
thanks harry
Post Posted: Tue Jan 01, 2013 4:18 pm
My '87 has been through two RWC without one, but a fitter told me it's quite a big fine if caught in roadside check.
bye
Post Posted: Tue Jan 01, 2013 4:22 pm
Ok so would it be worth putting one on incase
Post Posted: Tue Jan 01, 2013 8:21 pm
Technically an 86 model petrol 4wd isn't required to run a cat conv. but seeing as everyone now uses unleaded fuel I think every petrol vehicle should have a cat fitted.
Post Posted: Wed Jan 02, 2013 8:20 am
Ok so I don't NEED one I should just have one on.
The system has a cat but its straight off the back
of the Extractors and the cat hits the chassis rail
So that's why I wanted to know if I had to have one
Post Posted: Fri Jan 04, 2013 9:02 pm
if it runs as bad as most carby g13's a cat would be stuffed in about 10mins flat un burnt fuel will kill their coating
Post Posted: Fri Jan 04, 2013 11:29 pm
Myn is a g13b and it runs pretty good with the 2.5 inch system
Vehicle: SJ51T
Post Posted: Sat Jan 05, 2013 5:51 am
so you're running a GTI motor? If you are you need to legally run a cat.
Users browsing this forum: No registered users and 42 guests
