It is currently Mon Nov 02, 2026 10:19 am
Vehicle: 2000 Grand Vitara Sports
Post Posted: Fri Jan 04, 2013 12:43 pm
Both outer CV boots on my 2000 GV Sports Edition are split and require replacement. The boots have been split for a maximum of 2000km and most of the time the vehicle has been on tarmac. Local Suzuki dealership are quoting a fix with following parts/materials involved ( about $400 in labour on top of this )
snap ring x 2 $12.86
boot set x 2 $ 338.66
washer x 2 $ 15.06
seal x 2 $ 43.40
oil x 2 $ 30.00
They also indicate the following alternative involving replacement of the driveshafts with change over units ( about $300 labour to fit the replacements)
change over drive shafts $400.00
oil $ 30.00
I'm no expert here but this seems a bit extreme for 2 split outer CV boots. I rang a local workshop which advertises as a CV specialist and they quoted $125 per side to replace outer CV boots.
So I am confused, obviously I would like to spend as little as possible but at the same time don't want to spend so little that I get a poor job. Anyone else, particularly in Adelaide, got any recommendations/advise.
Thanks in advance
Post Posted: Fri Jan 04, 2013 12:54 pm
any good driveshaft/cv shop will be able to replace the boots without a drama, what side of town are you on?
Vehicle: Suzuki jb43 jimny
Post Posted: Fri Jan 04, 2013 1:23 pm
If ur down south mate I just had mine done both Sides, coste me 450 in parts and labour this was for rebuilt ones as there stronger. He also changed my hubs out and re greased em for me, if u want good service an price his names Dave brown and he owns and works for it as its his buiesness, it's called southern cv driveshaft and service center he's in Lonsdale a quick google will bring him up. He done mine on 5 hours very happy
Vehicle: 85 ' Drover
Post Posted: Fri Jan 04, 2013 1:46 pm
sounds like they dont understand that its just the boots that are stuffed, not the CV itself.
Ive replaced many CV boots (for other cars), and its generally been under $100 to replace all 4 rubber boots (excluding labor, its a pretty easy DIY job)
edit: reread your post, $384 for 4 bits of rubber boots? tell him he's dreamin. They are $11 each on ebay.
Post Posted: Fri Jan 04, 2013 2:06 pm
suzuki will only genuine parts... hence the prices. :wink:
Post Posted: Fri Jan 04, 2013 2:44 pm
Cheers for your reply, I'm in Clarence Park
Post Posted: Fri Jan 04, 2013 2:46 pm
ahh cool, i'm guessing you spoke to these guys? if not, give them a buzz http://www.driveshaftcv.com.au/
Post Posted: Fri Jan 04, 2013 2:51 pm
Thanks... I will call them as they are close to home.
Post Posted: Fri Jan 04, 2013 2:57 pm
pretty sure they'll be able to sort it out for you & at a fraction of the cost that suzuki quoted you.
Users browsing this forum: No registered users and 219 guests
