Joined: Sat Dec 29, 2007 10:30 pm Posts: 242 Location: launceston Tasmania
Posted: Fri Jan 16, 2009 10:42 pm
ok, quick question.... is there an easy way to get the speedo drive and hand brake cable disconnected from your transfer case? (1.3 nt) i have to take it down to workshop to get a new input shaft seal fitted but cant seem to disconnect either of these cables
Joined: Tue May 06, 2008 11:30 pm Posts: 2236 Location: Under Down Under
Posted: Fri Jan 16, 2009 11:03 pm
i'm not sure about the handbrake cable (i just took the whole handbrake off)
to take the speedo cable off just undo that bolt on the side of the case where the cable goes in and the cable should just pull out
_________________ [quote="Fluffy"] yeah right mate like Im gunna mov
Users browsing this forum: Google [Bot], sideways and 262 guests
