If you have the leads in the correct order then check that your distributor isn't 180 degrees out. Eg, when piston 1 is at TDC (top dead centre) the rotor button should be lined up with number 1 lead on the distributor cap. If it's 180 deg. out it will be pointing at number 4 lead.
Users browsing this forum: No registered users and 256 guests
