It is currently Sun Aug 02, 2026 10:00 am
Post Posted: Mon Feb 11, 2013 7:31 pm
hey all took my front bar off today to find only four bolts hold it on and was thinking when i get a bullbar will i need to drill holes in the mounts or is it held by four bolts cause it dosnt seem right cheers
Post Posted: Mon Feb 11, 2013 8:42 pm
mate these are the bullbar mounts that will come with the bar, they pick up the 4 stock mounting bolts. i drilled 2 m12s through the chassis to strengthen them.
i used these mounts to mount my winch bar and winched from them several times. theyre strong
EDIT: you dont need to use the m12s through the chassis. tjm designed them to just use the stock points
Post Posted: Mon Feb 11, 2013 9:06 pm
That's all there is stock - 2 little M8s. Not nearly enough to trust with a recovery pull IMO.
Most of us punch two M12s through those front nubs, some (I think Christover?) wrapped a mount down around the front crossmember as well.
Post Posted: Mon Feb 11, 2013 9:17 pm
My mounts are stock.
Tho bar is lifted to match the body lift.
Post Posted: Mon Feb 11, 2013 9:18 pm
I think stock, I have not changed anything, previous owner mat have ?
Post Posted: Tue Feb 12, 2013 5:49 am
Might end up getting arb bar, so thats the way to go by the looks of things but if I drill the two holes im mostlikly going to drill into the bullbar aswell which os not a problem
Cool cheers guys thanks for posting pics appreciated
Users browsing this forum: No registered users and 67 guests
