It is currently Sun Oct 11, 2026 1:43 am
Vehicle: 96 vit hardtop
Post Posted: Tue Feb 12, 2013 10:01 am
G'day guys
Long story short.
Pulled out an alloy diff from the wreckers, bought a steel diff. Bought a spartan locker in hope to swap housings and use internal alloy diff parts to build my new locked diff and throw it in after the diff guy did the setup for me.
Called me up and said the carrier is a one piece carrier and does not come apart so we cant fit the locker and gears into it. Carrier should unbolt so we can put the stuff in and close it all up, like the sierra ones do.
I was under the impression that the carrier in all alloy diffs were the same...what the hell is this thing. All the images i've seen online dont have an opening as large as on my carrier.
Diff guy says its def. a virgin diff.
The vitara I pulled this out of, was a later model one, not sure of year but it had the update dash...maybe the new ones had different diffs?
Post Posted: Tue Feb 12, 2013 12:28 pm
Looks like coily or Jimny.
Post Posted: Tue Feb 12, 2013 12:30 pm
Nah its def out of a vitara. I pulled it out myself at the pick a part...
Was out of an EFI vitara. But I have no idea what year it was. There were 3 there but this one had the engine out so it made it much easier to remove from the top...my laziness is my enemy!
Post Posted: Tue Feb 12, 2013 12:41 pm
does it have 26 spline side gears?
Post Posted: Tue Feb 12, 2013 12:44 pm
Side gears at the shop so I cant tell you. As a matter of fact, I also kept the CV's out of this same car. So I can check the CV's when I get home, but im 99% sure they are 26 spline, as my vit is currently 26 spline...
Post Posted: Tue Feb 12, 2013 12:53 pm
for reference, this is the front one that came out of my 1997 SV420
Post Posted: Tue Feb 12, 2013 12:58 pm
You're a champ. These are the exact type pics Im' looking for.
Yeah that's what I need, one I can open up and and work on the guts, and then bolt it all together. Not this side hole shit I have.
Post Posted: Wed Feb 13, 2013 10:13 pm
hate to burst your fantasy bubble mate but that carrier wont help you either , you need a 3 pin carrier like from the front or rear from a narrow track , or the rear of a wide track and then some machine work..
i cant see the spartan/lockrite reacting very well to only having 1 pin
Post Posted: Wed Feb 13, 2013 10:16 pm
Burst away! lol
Nah its been done by a few blokes on here with just 1 pin, and seems to work well.
Chris has had it in his vit for a while, and I hear he drives it pretty hard and it holds up just fine.
Low range have confirmed it will work just fine with the 1 pin, but a little weaker, but not too much.
Thanks for the heads up though!
Post Posted: Wed Feb 13, 2013 10:17 pm
Thanks to Built4Thrashing (lovley bloke) he hooked me up with the right carrier, so its getting dropped off tomorrow hopefully ready for the weekend!
Lots of great blokes on this site.
Users browsing this forum: No registered users and 267 guests
