| 1.3 quad carb blow through setup http://auszookers.com/forum/viewtopic.php?f=5&t=38949 |
| Author: | JrZook [ Tue Feb 12, 2013 2:47 pm ] |
| Post subject: | 1.3 quad carb blow through setup |
Not bad for a carb 1.3 setup May interest some of you.... http://www.theturboforums.com/threads/3 ... ow-through ![]() Dyno'd at 42RWHP bone stock. Rebuilt with 9.5CR, 1.6 head, cam, 32mm quads and k03 snail up to 147RWHP. 350% power increase with "bolt ons" on a pretty stock engine |
| Author: | jonno_racing [ Tue Feb 12, 2013 2:49 pm ] |
| Post subject: | Re: 1.3 quad carb blow through setup |
Now thats cool!!! wonder how long it took to tune.. |
| Author: | Ausuki [ Tue Feb 12, 2013 3:54 pm ] |
interesting i wonder how strong the bottom end of the 1.3 is? |
| Author: | Santos [ Tue Feb 12, 2013 5:53 pm ] |
Ausuki wrote: interesting. i wonder how strong the bottom end of the 1.3 is? i didn't read the build but sierra rods a beefier than swift rods. In fact they are as thick as GTi rods but have smaller pins connecting the pistons. People boost GTi all the time. Be interesting to know how well the car does without a turbo. Been mulling over a quad-1.4l NA G13 for some time now |
| Author: | JrZook [ Tue Feb 12, 2013 6:15 pm ] |
Santos wrote: Been mulling over a quad-1.4l NA G13 for some time now Before the turbo went on his engine with those simple mods was pushing just under 80HP at the wheels. Pretty much double over the stock configuration |
| Author: | Santos [ Tue Feb 12, 2013 6:47 pm ] |
You know now days i feel simple fixed-jet quad-carbs in an NA engine would better than CV or EFI. The reasoning being they are simple, reliable and robust design that can be fixed out in the field without dedicated gadgets. Tune time on buttefly fixed jets has to be considerbly less than CV carbs |
| Author: | JrZook [ Tue Feb 12, 2013 7:18 pm ] |
CVs are great! Just because they have more accurate metering and more fueling circuits doesn't mean they are wayyy harder to tune. Tune can be made considerably closer to the ideal than fixed jet carbs. They also don't need any dedicated gadgets to be worked on out in the field. Only butterfly fixed jet quad carb setup i can think of would be a weber side-draft setup and I don't think efficiency is an option with them. |
| Author: | neofitou [ Wed Feb 13, 2013 10:57 am ] |
How about Mechanical Throttle Body injectors. ![]() http://www.rotectbi.com/ The TBI-34 is what you want. |
