It is currently Fri Oct 09, 2026 6:57 pm
Post Posted: Tue Feb 12, 2013 9:18 pm
Did a quick search....
Anyone know what side of the car the Jimny interior light wiring runs down? Ours is a 2005 model. I'd like to tap into it and put a light in the rear somewhere, has anyone added additional lights to the cargo/rear area from the main interior light? It almost looks as though the roof lining has a moulded dent in it for an additional light, or other countries ran one.
Cheers and beers!
Superduki.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Wed Feb 13, 2013 12:56 am
Use a yellow tongue straight through the roof from the existing light to the back near the door and fit off your new light, someone here did that recently looks easy and good.
I cant find it its 2:25 am, Im on my phone and have work in a few hours.. bah
Post Posted: Wed Feb 13, 2013 5:33 am
yeah do it like that, just run some twin core from your new light and tap into the original one
of you tap in direct off the bulb holder you can make use of the off door on switch to work em both as well
Post Posted: Wed Feb 13, 2013 6:43 am
Spot on, thanks for the advice guys! That was my aim to operate it off the standard light switch configuration. They are an adequate light in the front, but now our windows are 20% it's a bit hard to see in the back at night!
Cheers, Superduki.
Post Posted: Wed Feb 13, 2013 8:41 am
Does anyone actually know the answer to this?
My interior is currently completely empty no seats or carpet and i may as well run the wire before i reinstall everything (after it dries).
Post Posted: Wed Feb 13, 2013 10:21 am
looks like drivers side.
Post Posted: Wed Feb 13, 2013 10:24 am
look down the right (or is it the left :S) hand side under the rear plastic panels?
they probs still run power down the back for that rear light, it's just not being used
Post Posted: Wed Feb 13, 2013 12:24 pm
I bought an led interior light off flebay lights up the whole car not a problem
Post Posted: Wed Feb 13, 2013 4:30 pm
no they do not, as no models uses it haha i dont think iv seen any Jimny with that rear light no matter what the spec. even the leather ones.
iv had the interior completely stripped out and there is indeed no cable in the body for that rear light indent that on the rear left.
as for interior lights
Image Image Image
Vehicle: 2012 jimny
Post Posted: Wed Feb 13, 2013 6:43 pm
I put a led light in that twist to front and back. Look in my build thread.
Post Posted: Wed Feb 13, 2013 11:34 pm
well there you go.
seems strange as there is even a hole for a switch for the back door.
I wired up a nice led light strip in my jimny a few years ago.
it's super bright :)
didn't even look for wiring as I wanted it to run off the second battery
Post Posted: Thu Feb 14, 2013 9:52 am
Benz wrote:
no they do not, as no models uses it haha i don't think iv seen any Jimny with that rear light no matter what the spec. even the leather ones.
well there you go.
depending on the year Jimny there is a rear door switch as mine (2005 VVT) has one, ;) if you have the hole there then you should have the wiring as well. its just an earth for the front door light i believe.
Users browsing this forum: No registered users and 134 guests
